Thread: What amount of KR is acceptable?
Results 1 to 20 of 34
  1. #1 What amount of KR is acceptable?
    GTP Level Member tms8582's Avatar
    Washington Michigan
    I know zero KR is the goal but sometimes I show just a blip of KR (0.2) under WOT between 2nd and 3rd shift. I've got my Aeroforce lights set up to light up over .2 on one light and the other light set up go off over 1.2. I've never seen the 1.2 light go off but the .2 one does most of the time under WOT between 2nd and 3rd. A degree of KR is 1.0 correct? So 0.2 is a twentieth of a degree correct? I'm guessing this is nothing to be concerned about? If so should I change the lights to go off over 1.0 and the other one 2.0? What amount of KR do you guys get concerned about?
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  2. #2 Re: What amount of KR is acceptable?
    Mullet Member Wotgtp's Avatar
    Connecticut
    The politically correct answer is 0, but once in a while I see 2.0KR and I don't worry much. If you see 0.0 timing being commanded. Worry.
  3. #3 Re: What amount of KR is acceptable?
    GTP Level Member Austins01GP's Avatar
    Nov 2010
    Maryville, MO
    .2 is two tenths of a degree, not a twentieth, but i would say you have nothing to be concerned about, ive often seen stock cars make 4.0 degrees and they seem to be fine
    i have my gauge set at like 5.0 degrees and i often see 2.0 and also dont worry. I wish I saw .2 at the most!
    // 1992 Nissan 300zx Twin Turbo (More RWHP than the Comp G)
    // 2005 Comp G
    CLICK ME!! for my Z Build and Comp G
  4. #4 Re: What amount of KR is acceptable?
    Washington Michigan
    Quote Originally Posted by Austins01GP View Post
    Two tenths of a degree is better terminology however a twentieth of a degree is the same amount lol Ok thanks guys, I'll change the settings on the lights to go off a 1.0 on one and 2.0 on the other. I won't get concerned unless I see both of them go off. I've got mild cam, headers, ported valve bowls on the heads and a 3.2 pulley btw. Showing about 18.5 on the injector pulse width and 10.5 psi of boost so I think it's pretty safe.
  5. #5 Re: What amount of KR is acceptable?
    GTX Level Member Neil98gt's Avatar
    May 2011
    Kansas city
    2/10 = 1/5. This does not equal 1/20.
    Sorry, bro.
    98 GT 2dr 116k, Sold
    07 Lexus ES350 Obsidian Black. Premium Plus package, sold
    2013 Hyundai Elantra GT
    2002 Grand Prix GT 4dr
  6. #6 Re: What amount of KR is acceptable?
    Nov 2010
    Maryville, MO
    Quote Originally Posted by tms8582 View Post
    yeah sounds like you'll be just fine LOL hows that thing run with the cam and pulley? i always wondered how my car woulda turned out if i woulda went through with camming it :/
    and not that it matters a whole bunch, but im pretty sure 1/20 (one twentieth) = 0.05 while 2/10(two tenths) = 0.2
    // 2005 Comp G
  7. #7 Re: What amount of KR is acceptable?
    Washington Michigan
    Quote Originally Posted by Neil98gt View Post
    Sorry, bro.
    Oh yeah I'm thinking 20% of a degree! DOH!
  8. #8 Re: What amount of KR is acceptable?
    GT Level Member comatoast's Avatar
    Nov 2012
    MN
    IF you set your gauge to go off at 1-2* KR, your gonna see an awful lot of red.. I had my aeroforce on 4* on my ssei, as it was a # That many thought was a good point to start watching what your doing.. Also The higher the RPM and boost the worse it is.. ex 2* kr will not be as damaging at 3000 rpm, and 4 psi, as opposed to 6000 rpm and 10+ psi
  9. #9 Re: What amount of KR is acceptable?
    ^ my thoughts exactly
    04 Comp G.
  10. #10 Re: What amount of KR is acceptable?
    Nov 2010
    Maryville, MO
    Quote Originally Posted by comatoast View Post
    hmm good to know. never thought about it like that before.
    // 2005 Comp G
  11. #11 Re: What amount of KR is acceptable?
    Washington Michigan
    Your right my bad. The car is running great! The Xtreme energy cam is a stage 1 type cam but you can tell its cammed at idle for sure. The 105 springs allow for higher rpm's and it's tuned with 6250 shift points. The higher rpms is a noticeable difference when your used to the factory 5800. I started off with a 3.3 pulley and it was much quicker but I was only getting 9.5 psi of boost and zero KR so I tried a 3.2. With the 3.2 I'm getting 10.5 psi of boost and just a tad of KR here and there so I'm maxed out for now. I am considering e85 and bigger injectors next because e85 is available all around where I live and I've heard it's good for another 20 to 30hp with a tune.
  12. #12 Re: What amount of KR is acceptable?
    Washington Michigan
    I don't think I will see much red at all with it set over 2.0 because I've never seen it get as high as 2.0. I think the 3.2 pulley is on the conservative side for my mods. Maybe your ssei was pushing the envelope a little more? Plus its a heavier car with more load on the motor. I just have so much money invested in this motor I want to be sure and error on the conservative side.
  13. #13 Re: What amount of KR is acceptable?
    I wouldnt even bat an eye if you saw 1-2º of kr.
  14. #14 Re: What amount of KR is acceptable?
    GTX Level Member JDrach's Avatar
    Nov 2011
    Indiana
    But wouldn't that little of KR (1*-4*) be alot mroe harmful with the set mods he has since he's running a smaller pulley?
    1998 Grand Prix GTP Daytona - CAI, XP Cam, Iceman tune, Speed Daddy Headers, 3.2 in pulley, Ported blower, Al 103's, 3in Catless DP, Transgo "shift kit", No resonator to Magnaflow Mufflers. 93K Miles
  15. #15 Re: What amount of KR is acceptable?
    Nov 2010
    Maryville, MO
    ive heard E-85 is the way to go if you can get a good tune for it.
    and as your car sits, i think you are right where you wanna be with pulley size and KR.
    // 2005 Comp G
  16. #16 Re: What amount of KR is acceptable?
    Washington Michigan
    Yes I've read on here from a few guys that e85 really is a good way to go. Right now its almost a buck less per gallon in Michigan too! I know that the car will get less mpg's but it about evens out with the cheaper cost at the moment at least.
  17. #17 Re: What amount of KR is acceptable?
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    People and their mathematical flaws lol. Nice looking car by the way
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  18. #18 Re: What amount of KR is acceptable?
    Think its been said, but the smaller the pulley the more damaging a * of KR can be. While you obviously dont want any, people forget how old school our KR sensors are and that they aren necessarily 100% correct ALL the time. What Im saying is, If you blip a degree or less (especially in mid shift) odds are its likely false knock. just look at what is happening when KR is happening. Do you have a lean spike? whats youre command timing at that given area? etc....
  19. #19 Re: What amount of KR is acceptable?
    Max Cook
    Guest
    Yeah more mods and boost means KR is more dangerous. 1-2 or less isnt really much to be concerned with on any build. Ideally you want 0 though within reason. If you're getting 2 degrees only at 140MPH thats probably not a concern. At 60MPH it might be a concern (as its probably only going to get worse). A lot of stock cars will have like 5* of KR and be fine because of the low boost levels.
    On another note with a 3.1 on a GenV I've hit 6-7 degrees of KR before multiple times without killing my car (asuming there aren't chipped pistons merely hiding away). I really don't reccommend that though.
  20. #20 Re: What amount of KR is acceptable?
    Washington Michigan
    Quote Originally Posted by gtpsleeper View Post
    Yeah this is exactly what is happening between 2nd and 3rd only. I wonder if it is false knock because my buddy ran his car with the intercooler off once and I remember his KR showing up much longer. Mine is only a blip mostly less than 1* and only between 2nd and 3rd at WOT. I'll take a closer look at the fuel condition and timing on some more runs and see. BTW I know your running e85 and a 2.8 pulley with a genV. Are you running an intercooler? How much boost are you getting?
  1. unbelievable amount of sludge in oil pan
    By john cola in forum General Tech Discussion
    Last Post: 10-22-2012, 08:34 AM
  2. Drain and refill amount
    By TEK310 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-10-2012, 01:18 AM
  3. Estimated amount to sell new ZZP stage II IC kit?
    By geforcextreme in forum General Tech Discussion
    Last Post: 10-23-2011, 12:05 PM
  4. Have a small amount of cash. DP, HV3, or PLOG?
    By spenc938 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-20-2009, 09:45 PM
  5. Acceptable KR, stock PCM, L36
    By Sabrewings in forum PCM Tuning
    Last Post: 04-21-2008, 10:03 PM
