Thread: Code P0452
Results 1 to 3 of 3
  1. #1 Code P0452
    Jul 2013
    Phoenix
    I know the code has to do w/ low pressure in the fuel tank, also that the sensor is located on the fuel pump. My car will run and drive fine (so far, bought it used and have traveled about 300 miles with it). My question is, if I have this code, but haven't had a stall, can I simply replace the sensor on the fuel pump, rather than changing the whole pump? Also, since we're here, how difficult is it to check/change fuel lines, and whatever electric wiring components there are that go to and from the engine and this sensor thing? Thanks a ton for help!
    Curtiss
    '02 GTP, stock for now!
  2. #2 Re: Code P0452
    Is more of a EVAP code, than a fuel pump code.
    To my knowledge there is not sensor like this on the fuel pump itself. I think it has to do with a wiring problem with the evap system.
  3. #3 Re: Code P0452
    Jul 2013
    Phoenix
    so, easy enough fix: replaced the fuel tank pressure sensor on the pump...no more check engine light!
  1. DTC Codes P0440 and P0452
    By Longshot in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-08-2011, 01:44 PM
  2. P0452?
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-03-2011, 08:29 PM
  3. P0452 Evaporative Emission Control System Pressure Sensor Low Input... huh?
    By JESSEGOTTA GP GT in forum General Tech Discussion
    Last Post: 05-04-2010, 11:47 PM
  4. PLEASE HELP! Codes P0102 & P0452
    By TAWinner23 in forum General Tech Discussion
    Last Post: 09-17-2008, 02:11 PM
  5. Runs bad, won't start...Codes P0401 & P0452
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-03-2008, 06:55 PM
