So when I have the engine apart to do a cam swap, gen V blower swap, pulley drop, headers. What are some maintenance things I should address while the motor is torn down? Things I already plan to replace lower intake manifold gasket, valve cover gasket, fuel filter, spark plug wires, spark plugs, thermostat, transmission filter, probably a coolant flush, and an oil change. Any other suggestions? Head gasket?
Thread is now a cam swap engine rebuild thread so if a mod could change the title that would be great.
