Thread: question about oil for 2002 GTP
Results 1 to 19 of 19
  1. #1 question about oil for 2002 GTP
    GT Level Member Dustoff's Avatar
    Mar 2014
    Canada
    so another question...
    the guy I bought my GTP off has been running
    -mobil 1 5w30 100% synthetic motor oil with lucas oil synthetic oil stabilizer.
    - royal purple supercharger oil
    - synthetic ATF with lucas synthetic ATF stabilizer
    - dexcool glycol rad fluid
    is this a good choice for my car? should I change anything?
    Thanks
  2. #2 Re: question about oil for 2002 GTP
    GT Level Member chamberlain198437's Avatar
    Grants Pass Oregon
    I would get rid of the dex cool, personal choice. People say your car won't run right by changing it out, I've never had a problem. Its very corrosive, i use good old green fluid. Again personal choice, as long as it's been flushed every few years you should be fine.
    Sent from my LG-L38C using Tapatalk 2
  3. #3 Re: question about oil for 2002 GTP
    Mar 2014
    Canada
    hmmm have any other members made that switch? comments please
  4. #4 Re: question about oil for 2002 GTP
    Mar 2012
    NC
    Quote Originally Posted by Dustoff View Post
    A lot of us switch to green...I switched to the all makes all models stuff just to save on the elctrolysis notorious with green coolant.
  5. #5 Re: question about oil for 2002 GTP
    SE Level Member 3800 Man's Avatar
    Mar 2014
    Indiana
    Best oil in my opinion is Castrol GTX. The majority of oil changes on my Bonneville SSEI (since sold) were GTX and she's still cranking at 356k miles.. Was pretty clean last time the valve covers were off.
    2002 Pontiac Grand Prix 40th Anniversary Edition 3.8 with K&N Intake......The War Machine
    Previously owned 98 Pontiac Bonneville SSEI but just sold it with 356,800 miles on her.
  6. #6 Re: question about oil for 2002 GTP
    Mar 2014
    Indiana
    Bonneville and now the Grand Prix were both on the green coolant. No Dex Cool anymore.
  7. #7 Re: question about oil for 2002 GTP
    Oil is oil as long as you keep up on oil changes and use the same stuff every time you should be fine.
  8. #8 Re: question about oil for 2002 GTP
    Nov 2011
    NY
    Dexcrap should be replaced...
  9. #9 Re: question about oil for 2002 GTP
    St. Louis
    Switched both my 95 Bonne and 00 GP GT to regular green coolant. I change it on a regular basis so no issues so far. As long as your LIM gaskets have been changed it should work fine.
    I run regular old Valvoline in both, and Wix filters. Never will a Fram touch anything that requires an oil filter. 214K on the Bonne and 314K on the GP GT.
  10. #10 Re: question about oil for 2002 GTP
    Mar 2014
    Canada
    Looks like I'll be making the switch to green. Thanks for the input everyone.
    preasure flush necessary? Or should I just flush it myself?
  11. #11 Re: question about oil for 2002 GTP
    Jun 2012
    south haven mi
    Don't use the lucas it makes your 5w30 into 10w40 at least, matter of fact don't use anything lucas if you care about your car.All you need is 5w30 in these engines.I watched one of my friends that calls himself a technician put lucas trans additive in his truck.It took about 15 mins to get it in and there was probably a couple ounces in the bottle when he threw it away lol.I just stood back smh.
  12. #12 Re: question about oil for 2002 GTP
    That stuff is like pure molasses
    Sent from A Galaxy Far Far Away........
  13. #13 Re: question about oil for 2002 GTP
    Jan 2013
    Australia
    amazed at the thin oil you guys use over there in the states... I know the weather is a lot colder than here in Aus... but a 30 weight oil seems excessively thin and just causes more unnecessary wear.
    Most people run 15w40 semi synthetic or 5w50 mobil1 here. My performance shop even goes up to 10w70 (although i think thats a bit too thick lol)
    Ive been using mobil1 5w50 and oil pressure is spot on 55psi at idle and around 60 with revs
  14. #14 question about oil for 2002 GTP
    Quote Originally Posted by slick2500 View Post
    This.. I'm not brand leghumper, I grab whatever syn is on sale at the time.
    Green coolant is what I run, can't stand the gunk that Dexcool brings.
    04 Comp G.
  15. #15 Re: question about oil for 2002 GTP
    Quote Originally Posted by Schwuppes View Post
    You crazy upside down people lol.
    15w40 is what we run in a semi or a standard diesel truck haha.
    If I lived in a warm place all year round, I'd gladly run a heavier weight oil and not care at all but being that I see temps well below 0ยบ F in the winter I stick with 5w30. Though we do run a 20w50 FULL SYN in older muscle cars.
  16. #16 Re: question about oil for 2002 GTP
    Florida
    I've switched all 3 of my GP's to regular green. Just flush yourself if everything looks alright (check for chunks in the overflow bottle, and check the radiator neck) if you see chunks or sludge, I'd get it flushed at a shop.
    I run 5w30 full synthetic, in whatever I can get for the cheapest, with a quality filter. (usually K&N or Mobil 1)
    Oil is oil. Only differences are in the additive packages.
    As far as the royal purple S/C oil, I can't comment cause I've honestly never known they made one. Most people just use GM S/C oil.
    Trans fluid, I run Dex IV or Dex VI.
  17. #17 Re: question about oil for 2002 GTP
    Jun 2012
    south haven mi
    The whole thick oil deal is the old way of thinking period.All the newer cars use 5w20 and 0w20 for a reason.GM has back spec'd a lot of thinner oil to be used in cars that once required 10w30 and higher, they obviously know something.Older L67's say 10w30 but the newer ones 5w30 for the same engine.My L36 has 200,000 and has a hair under 40psi in gear with 5w30 at full operating temp.
  18. #18 Re: question about oil for 2002 GTP
    Mercer, Pa
    0w is great for most vehicles during cold startup, gets the oil flowing. Doesn't actually effect the hot viscosity.
    20 is great for gas mileage and frees up some HP! It does reduce the engines life a little! Heard race teams run thin oil during qualifying.
    Synthetic has better viscous numbers when it gets really cold! Such as below 0 f.
  19. #19 Re: question about oil for 2002 GTP
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    What these two guys said. Oil is oil no matter what brand, it's just the additive packages that change slightly and ware out. As long as it replaced regularly, Don't worry about the oil brand too much.
    When it comes to Dex-cool vs. Green, I run Dex-cool. People blame Dex for eating away at gaskets (which it does when its abused). It eats away at plastic gaskets after 100k miles. Green isnt as acidic but does need to be changed more often. If you stick with Dex, flush every 80k to be on the safe side. It's not as bad as people make it sound, it's just people over look basic maintenance and blame the coolant at the issues.
  1. 2002 GTP dash air vent question
    By 45Longcolt in forum Introductions/Noob Questions
    Last Post: 06-12-2013, 05:06 PM
  2. 2002 Grand Prix GT Exhaust Options Question!
    By ddrum in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-17-2012, 11:24 PM
  3. 2002 Grand Prix GT fuel sending unit question?
    By Der2z in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-17-2012, 11:10 AM
  4. 2002 Grand Prix SE Headlight Switch Question
    By mrspindlelegs in forum General Tech Discussion
    Last Post: 06-27-2012, 04:42 PM
  5. 2002 GTP replacement cat question
    By toronado97 in forum General Tech Discussion
    Last Post: 03-08-2011, 05:20 PM
