Thread: Supercharger
Results 1 to 10 of 10
  1. #1 Supercharger
    Nov 2008
    Caguas, PR
    Hi all,
    I just bought a 1997 GTP and I was wondering how can I be certain the Supercharger unit is working properly? How does the boost meter work?
    Thanks in advanced for the help....
    AO
  2. #2 Re: Supercharger
    Banned
    Wichita Falls, Texas
    Does it have a belt on it? If so, it's working. The 'unit' does'nt just quit working without you knowing about it.
    Boost meter does nothing for displaying information. Buy a aftermarket boost gauge.
  3. #3 Re: Supercharger
    Donating Users
    W-S, NC
    ^ X2. As for the aftermarket gauge, its your choice, but why not do your gp a favor and look into a Aeroforce scan gauge. One gauge with so many parameters.
  4. #4 Re: Supercharger
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    What is making you think it's not working?
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  5. #5 Re: Supercharger
    Nov 2008
    Caguas, PR
    I was seeing very little movement in the boost meter and I was wondering if it was working. By the way I've read something about using a smaller pulley on the SC, what type of benefit is there in that?
    Thanks in advanced,
    AO
  6. #6 Re: Supercharger
    Donating Users
    W-S, NC
    Quote Originally Posted by LilAbner View Post
    Thanks in advanced,
    AO
    If its showing little movement on the DIC, It maybe have to do with your boost bypass valve not operating right. As far as the smaller pulley, it will increase boost resulting in more power, but you had better have the supporting mods and scan for knock retard or your motor will blow, even sooner if you dog it all the time. A car with a stock pulley with no knock will make more power than a smaller pulley with knock.
  7. #7 Re: Supercharger
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    well also the DIC gauge does not even start to move untill positive boost is read acording to my aeroforce and looking at the DIC Gauge
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  8. #8 Re: Supercharger
    Nov 2008
    Caguas, PR
    Thanks for the info... I'm hearing a some noise coming from the supercharger area while the motor is ide. It sonds like some is loose inside. Any Ideas on what this could be???
  9. #9 Re: Supercharger
    TDCRacing
    Guest
    You need a supercharger coupler. It's about 20 bucks and can be found here at ZZPerformance
    Would probably take about an hour to change. What happends is the hard plastic holes in the coupler get woddled out causing it to make that noise.
  10. #10 Re: Supercharger
    Bastard Reptile's Avatar
    Kansas City, MO
    An hour? LOL
    You're slow as molasses Parker.
    Like he said though, to test this, pull your belt off the supercharger, and turn it back in forth, if you feel a clunk, then it's absolutely your coupler.
    Another possibility is the rotor bearings are shot and the rotor pack needs replaced.
  1. Supercharger oil.. how often?
    By bentendo92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-04-2008, 06:33 PM
  2. supercharger pulleys
    By shagmobile20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-24-2008, 11:12 PM
  3. New supercharger pulley
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 06-24-2008, 12:01 AM
  4. supercharger gen q's
    By TDCRacing in forum General Tech Discussion
    Last Post: 05-06-2008, 10:13 PM
  5. American Supercharger MPS
    By MTXGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-17-2008, 09:44 PM
