Thread: Sqeeky supercharger belt
Results 1 to 20 of 22
  1. #1 Sqeeky supercharger belt
    Jun 2013
    Missouri
    I was wondering if anyone has a suggestion on how to quiet a sqeeky and sometimes sqealing supercharger belt on a 2002 Grand Prix GTP. I bought this car recently and the belt was making noise when i got it. Changed the belt and everything was fine for about a week and now the the noise is back. Have sprayed belt dressing several times but it only helps for a short time. The supercharger does have an aftermarket pulley on it and I was thinking that maybe this could be the problem. Has anyone had a problem with this type of pulley upgrade?
  2. #2 Re: Sqeeky supercharger belt
    If the pulley is smaller you need a smaller belt
  3. #3 Re: Sqeeky supercharger belt
    St. Louis
    Not only that, but does this GTP have a way to be scanned for KR? Supporting mods for pulley drop? I hope that if it's a smaller pulley that you have the mods to go with it or you could be looking for a new motor in the near future.
    Oh, and in case you don't know (we can't assume everyone does), make sure to run at least 91 octane in it, 93 if you can get it. GTP's require premium fuel.
  4. #4 Re: Sqeeky supercharger belt
    Jun 2013
    Missouri
    I don't know if the pulley is smaller than stock. What does a stock one measure? I also have no idea if any other mods have been done to the engine. I do run 91 octane gas and have not noticed any pinging.
  5. #5 Re: Sqeeky supercharger belt
    Stock size pulley is a 3.8"
    04 Comp G.
  6. #6 Re: Sqeeky supercharger belt
    Jun 2013
    Missouri
    Thanks
  7. #7 Re: Sqeeky supercharger belt
    GTP Level Member rodguezsciii's Avatar
    Sep 2012
    you can run a stock belt down to a 3.6
    .....some ppl replace the belt and tensioner at the same time to avoid any future problems....I would take the belt off and spin pulleys, make sure everything is ok first....
  8. #8 Re: Sqeeky supercharger belt
    GT Level Member JaredR215's Avatar
    Jul 2011
    Cheyenne
    If the belt was replaced with one that is too small it will start squeaking soon after replaced.
    K&N Cold Air, ZZP Wires, ZZP 3" with hi-flo, Catback, ZZP 1.0 PCM., 180*, AL605's, 3.5 MPSStill fighting KR
  9. #9 Re: Sqeeky supercharger belt
    To big you mean?
  10. #10 Re: Sqeeky supercharger belt
    Jan 2012
    Philadelphia
    Quote Originally Posted by rodguezsciii View Post
    I have a stock belt on my 3.4 pulley and it works fine, not saying its the right thing to do but it can be done.
    Check and make sure the belt is all the way on at the crank pulley, sometimes they jump off a rib or 2 and they squeak happened to me before. And also try and take your belt off and check all your pulleys to see it they spin nice could be a bad idler pulley.
  11. #11 Re: Sqeeky supercharger belt
    Jun 2013
    Missouri
    Will check to see if belt has moved over a rib or two. Never thought of that.
  12. #12 Re: Sqeeky supercharger belt
    Jul 2011
    Cheyenne
    To big you mean?
    No I mean too small. Parts store gave me a belt a half inch too short once. It was terrible trying to get it on, about a week later it started squeaking.
  13. #13 Re: Sqeeky supercharger belt
    Jun 2013
    Missouri
    Checked pulley and it is a 3.3...the brand is American Supercharger and I don't know anything about them except they are a modular system sold on eBay...ordered a new belt that is 1 inch shorter than stock and will see if that helps.
  14. #14 Re: Sqeeky supercharger belt
    I woulda got a stock pulley aswell, not such a good idea to have a 3.3 pulley without knowing if you even have the mods to run it.
  15. #15 Re: Sqeeky supercharger belt
    Jun 2013
    Missouri
    The exhaust has been modified but not sure if anything else has been done.
  16. #16 Re: Sqeeky supercharger belt
    Jul 2011
    Cheyenne
    In for chipped pistons. By exhaust are we talking just different mufflers? Check the downpipe or check for aftermarket headers atleast.
  17. #17 Re: Sqeeky supercharger belt
    Yup u might want to pick up a stock pulley. If the engine isn't already messed up it won't be to long until it is. I doubt the car has the proper mods to run a 3.3 safely even with some exhaust work it takes more then that.
    04 Comp G.
  18. #18 Re: Sqeeky supercharger belt
    Jun 2013
    Missouri
    Different downpipe and gutted cat
  19. #19 Re: Sqeeky supercharger belt
    That still doesn't equal you being able to run a 3.3 safely.
    04 Comp G.
  20. #20 Re: Sqeeky supercharger belt
    I hate to be a negative Nancy and I'm no Cleo but I do see a piston or pistons going KABOOM in the very near future if it hasn't already.
    04 Comp G.
  1. supercharger belt
    By mikey666 in forum General Tech Discussion
    Last Post: 05-07-2013, 05:33 AM
  2. supercharger belt
    By nvrstsfd23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2013, 09:09 AM
  3. Supercharger belt
    By Bragill25 in forum Introductions/Noob Questions
    Last Post: 09-19-2012, 06:13 PM
  4. Supercharger coupling OR Supercharger belt tensioner?
    By 99gtxws6 in forum General Tech Discussion
    Last Post: 07-23-2010, 11:56 AM
  5. Supercharger Belt Came Off!!
    By jjwalton77 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-14-2008, 03:34 AM
