Thread: what oil can be used in s/c
Results 1 to 15 of 15
  1. #1 what oil can be used in s/c
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    Just wondering if i can use some otger oil instead of s/c oil like gear oil or some sort of light weight engine oil lmk
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  2. #2 Re: what oil can be used in s/c
    You can run a Full syn 5w20 or 5w30 for a short time period if you can't get supercharger oil right away.
  3. #3 Re: what oil can be used in s/c
    Looks like my snout seal is shot leaked out quick
    sold 97 GTP stock
  4. #4 Re: what oil can be used in s/c
    Guess ill run some thick gear oil lol
    sold 97 GTP stock
  5. #5 Re: what oil can be used in s/c
    I wouldnt run a real thick oil in it, be best to just replace the seal.
  6. #6 Re: what oil can be used in s/c
    Whats the worst that could happen
    sold 97 GTP stock
  7. #7 Re: what oil can be used in s/c
    Dec 2012
    Where 4T65E's were born
    Increased wear resulting in a decrease in life?
    Sold.
  8. #8 Re: what oil can be used in s/c
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  9. #9 Re: what oil can be used in s/c
    GT Level Member orange57's Avatar
    Aug 2012
    Chandler, AZ
    Quote Originally Posted by buck531 View Post
    So, did he win?
  10. #10 Re: what oil can be used in s/c
    Quote Originally Posted by nascartech View Post
    Rebuilding it or look for a used assuming you have a gen 2 snout off here?
    04 Comp G.
  11. #11 Re: what oil can be used in s/c
    Arizona
    i used some mobil 1 75 90 gear oil for a long time on my gtp with no issues or leaks
  12. #12 Re: what oil can be used in s/c
    How hard is it to change the seal never done it before
    sold 97 GTP stock
  13. #13 Re: what oil can be used in s/c
    I believe you need a press to take apart the snout. I haven't heard of anyone that went that route normally they just spend a few bucks and buy a snout off here.
    04 Comp G.
  14. #14 Re: what oil can be used in s/c
    May 2008
    Schuyler, NE
    Gear oil is too thick. I've used 10w-30 mobile 1 before for about 10k miles without issue. It's best to use S/C oil though.
  15. #15 Re: what oil can be used in s/c
    TLsheff has a copy of the tech bulletin saying 5-20 or 5-30 mobil one full syn.
    Rebuilding isn't bad if you have an idea what you are doing. Which is easy if you reference rollingperformance.com's how to.
