Thread: Valvetrain parts ?
Results 1 to 20 of 26
  1. #1 Valvetrain parts ?
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    Just try to find cheaper prices then zzp so ls1 valve springs and ls1 lifters will fit right? And what about locks and retainers any help woyld be great.
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  2. #2 Re: Valvetrain parts ?
    May 2008
    Schuyler, NE
    Yes, they fit. You will want LSx retainers as well. Just reuse your stock valve locks.
  3. #3 Re: Valvetrain parts ?
    Lsx ?
    sold 97 GTP stock
  4. #4 Re: Valvetrain parts ?
    Quote Originally Posted by nascartech View Post
    Lsx ?
    Does that just mean any ls motor like abreviationfor ks 1,2,6,7 etc
    sold 97 GTP stock
  5. #5 Re: Valvetrain parts ?
    May 2008
    Schuyler, NE
    ^^yes.
  6. #6 Re: Valvetrain parts ?
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    ls6 springs are cheapest on ZZP (go figure) and LS7 lifters for a set or 16 are cheapest on JEGS. When I bought mine.
    97 Bonneville SE Not so much a 97 anymore
  7. #7 Re: Valvetrain parts ?
    Quote Originally Posted by Nighthwk12 View Post
    Thanks guys also when i put my cam in should i change the chain or just the tentioner trying to do this cheap as possible
    sold 97 GTP stock
  8. #8 Re: Valvetrain parts ?
    I would run 105's vs. LS6's.
  9. #9 Re: Valvetrain parts ?
    Nov 2009
    Central Jersey
    rock auto is good for that also for the gaskets the Fel pro Lower conversation gasket set will give you all the goodies you need other than LIM gasket, super charger gaskets, and coolant elbows
  10. #10 Re: Valvetrain parts ?
    Quote Originally Posted by blueguy View Post
    Only running a nic cam
    sold 97 GTP stock
  11. #11 Re: Valvetrain parts ?
    May 2008
    Schuyler, NE
    Go with 105's. They are a better spring.
    Get a new chain and dampner too.
  12. #12 Re: Valvetrain parts ?
    Max Cook
    Guest
    You can go cheap and get valve float and a broken chain or spend a little bit more money and have **** work.
  13. #13 Re: Valvetrain parts ?
    Quote Originally Posted by Max Cook View Post
    I just ordered so im gunna see if i can cancel tge 90lb springs and get 130
    sold 97 GTP stock
  14. #14 Re: Valvetrain parts ?
    Max Cook
    Guest
    130s are harder on the chain but you shouldnt have any chance of Valve float. I would get crow 105s if I were you.
  15. #15 Re: Valvetrain parts ?
    May 2008
    Schuyler, NE
    Don't get 130's. Get 105's or 110's.
  16. #16 Re: Valvetrain parts ?
    Got 130s double roller and stage 3 intense cam will this be good will prob need to upgrade transmission now lol
    sold 97 GTP stock
  17. #17 Re: Valvetrain parts ?
    Max Cook
    Guest
    If its a stock tranny it will die eventually, depending on how you treat it. It will die faster with that setup but who knows how long it'll last. Completely irrelevent to the springs/chain setup though. 130s with a double roller should work out alright.
    What made you change your mind on the NIC cam?
  18. #18 Re: Valvetrain parts ?
    Just decided if im gunna do it go big lol
    sold 97 GTP stock
  19. #19 Re: Valvetrain parts ?
    IS3 is big?
    lol.
  20. #20 Re: Valvetrain parts ?
    Biggest for a m90 other cams would bleed off to much thats what john at intense told me
    sold 97 GTP stock
  1. Valvetrain parts
    By synysterjoe in forum Wanted To Buy - Parts
    Last Post: 06-03-2013, 12:49 PM
  2. Should my valvetrain be ok for an S1X cam?
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-23-2011, 08:43 PM
  3. Valvetrain noise?
    By shawn3091 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2011, 01:54 PM
