Thread: knock sensor question...
Results 1 to 3 of 3
  1. #1 knock sensor question...
    Massachusetts
    If you run the l67 with the knock sensors unplugged, how does that change the timing in the engine ( if at all? ) I know in other motors, like the LS1, the engine will add a constant 4* KR when the sensors are unplugged...
    and yes, I am well aware of the risks of no knock sensor, this is simply a question.
    Thanks!
    2003 GS
  2. #2 Re: knock sensor question...
    I'm not 100% sure, but likely the car just wont have a way of knowing anything if it does knock.
    The SES will come on too I'm pretty sure.
    The V8 pcm's are like 5x more advanced than these dumb V6's.
  3. #3 Re: knock sensor question...
    Not sure either..I'd have to look up a knock sensor code in the FSM and see what it says happens based on a failure etc. You could assume whatever the default for failing sensor does is likely what unplugging would do.
  1. Rear knock sensor / power steering pump / rack & pinion question
    By miwalter928 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-21-2012, 09:38 AM
  2. EGR and knock sensor question
    By GTLGDP in forum General Tech Discussion
    Last Post: 04-25-2012, 06:31 AM
  3. knock sensor
    By Stock4now in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-09-2011, 06:52 AM
  4. Front Knock Sensor Removal Question
    By nickbuol in forum General Tech Discussion
    Last Post: 07-23-2009, 08:22 AM
  5. knock sensor?
    Last Post: 10-20-2008, 12:19 AM
