I know the code has to do w/ low pressure in the fuel tank, also that the sensor is located on the fuel pump. My car will run and drive fine (so far, bought it used and have traveled about 300 miles with it). My question is, if I have this code, but haven't had a stall, can I simply replace the sensor on the fuel pump, rather than changing the whole pump? Also, since we're here, how difficult is it to check/change fuel lines, and whatever electric wiring components there are that go to and from the engine and this sensor thing? Thanks a ton for help!
Curtiss
'02 GTP, stock for now!
