Thread: Replacing L67 bottom end for L26 bottom end
Results 1 to 10 of 10
  1. #1 Replacing L67 bottom end for L26 bottom end
    SE Level Member OcalaGTP's Avatar
    Nov 2012
    Fl
    I have a rod knock on my 2002 GTP. I can find L26 blocks everywhere for cheap. I have done some top swap research. Just had a few things i couldn't really find.
    Does the L26 block bolt up to the HD l67 trans?
    Does the car have to be re tuned ?
    Do all the accessories bolt up the same?
    Motor mounts?
    Any other issues ?
    Will the L36 be any better?
  2. #2 Re: Replacing L67 bottom end for L26 bottom end
    every thing bolts right up. you will need a tune tho.
  3. #3 Re: Replacing L67 bottom end for L26 bottom end
    May 2008
    Schuyler, NE
    Everything does bolt up. But, you will need to change the heads over to L67/L32.
    You will also likely need more than a tune, due to the higher compression. Cam, IC, or bigger pulley.
  4. #4 Re: Replacing L67 bottom end for L26 bottom end
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Quote Originally Posted by OcalaGTP View Post
    Motor mounts?
    Any other issues ?
    The L26 will bolt right up to your L67 trans but you will want to use YOUR L67 flex plate.
    Yes you will want to have it tuned. Look into what other mods you want to change/add while you have a tune done.
    Everything bolts right up. IF you get a L26 with the aluminum oil pan you will have to get the motor mount for that pan OR grind your horseshoe bracket down for clearance. I just grinded mine down then painted it.
    You will have to swap everything heads up from the L67 to your L26. I got a low mileage L26 and used the L26 ICM, coils, all the sensors on my 99. It's very easy.
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  5. #5 Re: Replacing L67 bottom end for L26 bottom end
    The Boss Iceman6669's Avatar
    Jun 2011
    I would recommend using the flex and Converter from the L26
    2011 F-150 Yote powered
  6. #6 Re: Replacing L67 bottom end for L26 bottom end
    i wouldn't use a t verter form a un known tranny. it holds a lot of fluid and can contaminate your good tranny if its got metal shards in it.
  7. #7 Re: Replacing L67 bottom end for L26 bottom end
    Portland Oregon
    Don't bother swapping flex plates. The l26 has a dual drilled plate. I just did this on my drag car. I would just throw some headers on while you're in there. You can probably get away with same size pulley and a tune
  8. #8 Re: Replacing L67 bottom end for L26 bottom end
    May 2008
    Schuyler, NE
    Yes, the L26 flexplate has both the 258mm and 245mm bolt pattern drilled on them.
  9. #9 Re: Replacing L67 bottom end for L26 bottom end
    GT Level Member jlgp2007nc's Avatar
    Sep 2012
    North Carolina
    Hmm good to know
  10. #10 Re: Replacing L67 bottom end for L26 bottom end
    Nov 2009
    Tennessee
    Very good to know!!! Glad GM finally learned to make things more universal....
  1. bottom swap, or how i learned to rebuild the bottom end completely
    By almighty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-18-2009, 03:37 AM
  2. bottom end
    By rodman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-27-2008, 11:01 AM
  3. Out The Top or Through The Bottom
    By SyntheticShield in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-20-2008, 01:07 PM
