Thread: Boost gauge can't be right...
Results 1 to 13 of 13
  1. #1 Boost gauge can't be right...
    SE Level Member JerzNick's Avatar
    Oct 2012
    New Jersey
    Sup all, Here is a pic of my gauge at idle showing 16psi VAC... At WOT it goes to +4... is that all the boost I'm getting?
    I have the gauge T'd in between the map and lim, No vac leaks that I can tell, fuel trims are just about perfect.
    Any ideas?
    Also, Im running a 3.0 pulley with out an IC, just ported heads, headers and xp cam. Should I go up in pulley size to be safe?
    Thanks
    Bored block, Eagle Crank, XP Cam, Ported Heads/LIM/Blower/TB, 3.0 Pulley, CAI, Headers, 42.5#, AL 104's, etc...
  2. #2 Re: Boost gauge can't be right...
    Feb 2009
    flintnasty MI
    Sounds about right assuming your bbv is broken.
  3. #3 Re: Boost gauge can't be right...
    Oct 2012
    New Jersey
    BBV is fine, the BBS is shot... Unplugged it and now seeing 12lbs
    Thanks
  4. #4 Re: Boost gauge can't be right...
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Vacuum is right. I stay right around 14 (whatever units) at idle and I have a similar setup as you, just top swapped with a 3.4. I see 9psi at WOT
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  5. #5 Re: Boost gauge can't be right...
    Oct 2012
    New Jersey
    Quote Originally Posted by dbextreme View Post
    Just out of curiosity, what made you choose a 3.4?
  6. #6 Re: Boost gauge can't be right...
    Feb 2009
    flintnasty MI
    Quote Originally Posted by JerzNick View Post
    high compression lower end and pump gas I assume.
  7. #7 Re: Boost gauge can't be right...
    Nov 2009
    Tennessee
    What dark said... And it's a common size to start with from what I read. Right now I am seeing 0 KR so I will venture into dropping pulleys eventually. I really want to go Intercooled, but am happy with the setup at the moment.
  8. #8 Re: Boost gauge can't be right...
    Oct 2012
    New Jersey
    I'm seeing some small kr in high rpm... I tried to back off the timing but it's not helping. Looks like I'll be going up to 3.4 just to be safe.
  9. #9 Re: Boost gauge can't be right...
    Since you don't have a BBV or BBS.. you know.. lol
    BCA and BCS if you are interested.
  10. #10 Re: Boost gauge can't be right...
    Oct 2012
    New Jersey
    I have the BBV. Just the solenoid is unplugged. Is that bad long term?
    What's bca/bcs?
  11. #11 Re: Boost gauge can't be right...
    What's bca/bcs?
    Check with GM.. you don't have a BBV, because you don't have a turbo. BCA Boost control actuator. BCS boost control soleniod.
  12. #12 Re: Boost gauge can't be right...
    Feb 2009
    flintnasty MI
    The solenoid never does anything on a stock car, so having it unplugged is no different than having it plugged in.
  13. #13 Re: Boost gauge can't be right...
    Nov 2009
    Tennessee
    Once I get a few more miles on the car (and while I collect pulleys from 3.0 - 3.3) then I'll drop sizes to find one the motor likes.
    AS for the BBV solenoid, I removed mine completely. I capped off the piece that branched off the FPR and I left a 2-3" pig tail of vacuum line off the back of the BBV just open to atmosphere. Works great so far.
  1. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  2. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
