Thread: l67 engine wont stay running..got the car running. tons of white smoke from exhast
Results 1 to 8 of 8
  1. #1 l67 engine wont stay running..got the car running. tons of white smoke from exhast
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    when i start my car the idle is kinda rough and then out of nowhere the idle starts to climb to about 1k then drop to like 5 then up then down and then it cuts out. could it be my IAC? or even the MAF? i cant test anything tonight because i ripped my throttle body gasket and i cant get one until tomorrow
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  2. #2 Re: l67 engine wont stay running.
    If you can't test anything today, then we really can't help you right now.
    Seems that you already have an idea of what the problem may be, so do some trouble shooting and see where that gets you.
  3. #3 Re: l67 engine wont stay running.
    Sep 2011
    palm harbor florida
    i have my old throttle body and i tryed swapping over the iac and other components over and it turns out the iac was bad but the car was still playing up. tomorrow if it still does the same thing after i put the gasket on im going to unplug the maf to see how the car reacts.
  4. #4 Re: l67 engine wont stay running.
    If you have a bad gasket..you have a self induced vacuum leak.
  5. #5 Re: l67 engine wont stay running.
    Sep 2011
    palm harbor florida
    well when i replaced it the first time i guess it didnt seal properly and there was a pretty bad leak on the right side of the throttle body
  6. #6 Re: l67 engine wont stay running.got the car running. tons of white smoke from exhast
    Sep 2011
    palm harbor florida
    i got it to run and now there is tons of white smoke billowing from exhaust
  7. #7 Re: l67 engine wont stay running..got the car running. tons of white smoke from exhas
    When the gasket was bad.. was it bad in the area that would let coolant into the motor?
  8. #8 Re: l67 engine wont stay running..got the car running. tons of white smoke from exhas
    Sep 2011
    palm harbor florida
    no it just never sealed properly on the top but everything is fine now car runs greats and starts right up
  1. Car wont stay running
    By krippled in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-26-2013, 01:43 PM
  2. help car wont stay running
    By izup69 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-18-2012, 07:27 PM
  3. wont stay running
    By DarkCherry in forum General Tech Discussion
    Last Post: 09-24-2010, 11:06 PM
  4. need help car wont stay running
    By ALACEY in forum Introductions/Noob Questions
    Last Post: 07-03-2010, 11:58 PM
  5. car wont stay running
    By 98gpgtp in forum General Tech Discussion
    Last Post: 04-17-2010, 07:41 AM
