Thread: Need some help.....
Results 1 to 20 of 21
  1. #1 Need some help.....
    SE Level Member CRU1Z3R's Avatar
    Apr 2012
    Western, KY
    So here's the problem I've been dealing with for some time, car won't start on its own, I actually have to give it gas to get it started, and it won't stay running either, after letting off the throttle it just bobbles and dies. So I read alot on these forum and others and convinced myself that it had to be the fuel pump. Bought a Fuel Pressure gauge and tested my pressure at the fuel rail, and guess what it was only getting 38psi when I would turn on the ignition, and then would rapidly die down to 0psi.
    So I just got done replacing the fuel pump, wasn't too bad to do, just hard on an old fat guy. And guess what, I get adequate pressure now, but still it's doing the same thing! So I'm pretty sure if I remember correctly that when this happened before I replaced that Fuel Pump Resistor/Ballast Resistor and it fixed my problems....So I was curious and tested the resistance on the FPR and I get .7 ohms of resistance, does anyone know what it's actually supposed to be??
    And I'm kinda of at the end of my rope here, if it's not the FPR, then where should I go next MAF sensor? Crank, camshaft sensor? any help would be greatly appreciated!
  2. #2 Re: Need some help.....
    Replace the fuel pressure regulator
  3. #3 Re: Need some help.....
    The pressure regulator is the reason its bleed all its pressure.
    I bet if you disconnect the rubber vacuum line going to it, some fuel will come out or it will be all wet.
  4. #4 Re: Need some help.....
    Apr 2012
    Western, KY
    After replacing the Pump today tho it's doesn't bleed back down.... I will go check it tho. Thanks for quick response!
  5. #5 Re: Need some help.....
    Apr 2012
    Western, KY
    Just checked it...
  6. #6 Re: Need some help.....
    Okay, so with the new fuel pump it makes full pressure but now doesnt bleed off?
    And still has the hard start issue?
  7. #7 Re: Need some help.....
    Apr 2012
    Western, KY
    Yeah Fivefinger that's right....new Fuel Pump it kicks up to 45psi, and stays there now, it doesn't bleed off anymore, but still the same issue, you can just sit there and crank it all day and it won't start until you give it gas, then it will fire right up, but won't hold an idle, if you take your foot off the pedal it just dies...
  8. #8 Re: Need some help.....
    Okay. No longer a fuel issue.
    Unplug the MAF sensor and give it a go.
    Kinda sounds like a maf problem.
  9. #9 Re: Need some help.....
    HUDSON
    The "gas" pedal an a FI car does not really give it "gas", it gives it "air". Not like the old carburetors that actually gave the engine "gas" when the pedal was depressed.
  10. #10 Re: Need some help.....
    Right, but the throttle position % does tell the car to turn up the amount of fuel to deliver.
  11. #11 Re: Need some help.....
    Apr 2012
    Western, KY
    Without MAF sensor
  12. #12 Re: Need some help.....
    Apr 2012
    Western, KY
    With MAF Plugged in
  13. #13 Re: Need some help.....
    Hmm, so maybe not MAF sensor.
    Damn this is getting tough lol.
    I wish I still had access to alldata right now to check that ohms reading you got.
  14. #14 Re: Need some help.....
    Apr 2012
    Western, KY
    Man this has been going on for about 2 months now....I'm sooo frustrated with it, I just want it to run again, and I keep thinking it's going to be something super simple and super cheap, but I have ran out of ideas..
  15. #15 Re: Need some help.....
    Apr 2012
    Western, KY
    I have HPTuners software on my laptop, I can scan and post the data on here if that will help anyone help me out...
  16. #16 Re: Need some help.....
    HUDSON
    Is the IAC (Idle Air Control) motor working properly?
  17. #17 Re: Need some help.....
    Apr 2012
    Western, KY
    I did replace that a little while ago, how would I tell?
  18. #18 Re: Need some help.....
    Apr 2012
    Western, KY
    So got home from work, took the throttle body off the car, and took off the IAC, and when I did this is what I found
    the o-ring that was around the base of the IAC was smashed, and it wasn't seated correctly, and I guess there another o-ring came from somewhere else and my have been jamming the actual movement of the valve...Thoughts?? Anyway to test these?
  19. #19 Re: Need some help.....
    Apr 2012
    Western, KY
    Anywayz, Thought I would check back, replaced the IAC and cleaned my MAF with MAF cleaner and also the throttle body, and guess what, she fires right up first thing now, silly how it was that one part, although it does seem that my fuel pump was on the way out down 8psi from what it should have been, so I don't feel like I wasted any of my time or money, especially since who knows when it would have failed....Thanks for everyone's help!
  20. #20 Re: Need some help.....
    SE Level Member sco77's Avatar
    MD
    I was going to say a stuck open injector, since that would cause all those symptoms and would need more throttle (more air) to be able to make up for the fuel dump... But it looks like you found the problem and that wasn't it.
    98 GTP - Retired
    86 Fiero GT - L67 | VS Cam | Polished GenV | Headers to 3" Catback to dual/dual Tips | 42.5# | N*
