Thread: po171
Results 1 to 20 of 23
  1. #1 po171
    GT Level Member 01GrandPrixTURBOGT's Avatar
    Dec 2011
    Decatur
    Ive been fighting a lean condition for awhile now and it finally through the po171. LTFT's are at 16.4 but when driving around itll go down to 3 and very depending on mph and where the rpm is at WOT its at zero though. Ive checked my egr tube and vacuum lines with no luck. My car only makes 5 psi on stock pulley but when its about to shift itll hit 6.2psi which is where it was at the beginning. And it has lost some power. Idle doesnt seem very ruff.
  2. #2 Re: po171
    Check for vacuum leaks.
    Check your crossover for an exhaust leak.
    Try cleaning your MAF sensor as well.
  3. #3 Re: po171
    Dec 2011
    Decatur
    If I put a string by the crossover and theres a leak it would blow the string away?
  4. #4 Re: po171
    Possibly but it would be easier to run some seafoam through the vacuum lines and see where it smokes out of
  5. #5 Re: po171
    Dec 2011
    Decatur
    Is that okay on the motor I've heard seafoam can do more harm than good sometimes
  6. #6 Re: po171
    It Won't hurt anything
  7. #7 Re: po171
    Dec 2011
    Decatur
    Anyone have an idea why my uim gasket has a vacuum leak again I just changed i, but its got smoke leaking again.
  8. #8 Re: po171
    Maybe it was bad out of the box?
    What brand gasket was it?
  9. #9 Re: po171
    Did you torque the bolts down tight enough? Is the plastic cracked?
  10. #10 Re: po171
    UIM gasket being the SC gasket. Where is it leaking?
  11. #11 Re: po171
    Dec 2011
    Decatur
    Felpro. And the smoke comes out right below the snout.
  12. #12 Re: po171
    Disregard my last post i was thinking l36. Is your LIM ported or stock?
  13. #13 Re: po171
    Dec 2011
    Decatur
    It's stock.
  14. #14 Re: po171
    Dec 2011
    Decatur
    What's the extra holes for inbetween the valvecover bolts.
  15. #15 Re: po171
    pics?
  16. #16 Re: po171
    Dec 2011
    Decatur
    I'll try to get pics up. My laptop broke so but I'm trying to get it fixed soon. But if you look by the valvecovers you can see the bolt holes in between the humps. There part of the heads.
  17. #17 Re: po171
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Mount holes? I know the front pass motor mount bolts to the head, if you have the L67 bracket then those holes will be there but nothing in them. Rear head has the same holes but I forgot what goes into them, some bracket of some sort...
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  18. #18 Re: po171
    Dec 2011
    Decatur
    Ok thanks them are what I was talking about. Well anyone have any ideas why it keeps leaking? I'm going to try changing it again soon but anyone have an idea on what to look for?
  19. #19 Re: po171
    Dec 2011
    Decatur
    Supercharger gasket ^
  20. #20 Re: po171
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    you forget to tighten the bolt right next to the snout?
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  1. trouble code po171 bank 1
    By peter in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-12-2012, 01:21 PM
  2. po171 under heavy throttle
    By nascartech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-23-2010, 01:26 PM
