Thread: what are the benefits of an egr delete?
Results 1 to 16 of 16
  1. #1 what are the benefits of an egr delete?
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    i was justing thinkint to my self if i did an egr delete i will throw a code right? and what are the benefits of deleting it ?
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  2. #2 Re: what are the benefits of an egr delete?
    Slightly less mpg, a check engine light and if you are in an emissions state...a failure sticker.
  3. #3 Re: what are the benefits of an egr delete?
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    To me thats 3 negatives and no positives. Why would you do it for less mileage?
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  4. #4 Re: what are the benefits of an egr delete?
    Ok.. one more..
    A cleaner intake tract.
  5. #5 Re: what are the benefits of an egr delete?
    Sep 2011
    palm harbor florida
    ya i dont think im going to do that lol
  6. #6 Re: what are the benefits of an egr delete?
    Wuss
  7. #7 Re: what are the benefits of an egr delete?
    cleans up the engine bay a lot.
    setting the code to no report is super easy.
    and loss of mpg is more prominant with misuse of your right foot than the EGR delete would do.
  8. #8 Re: what are the benefits of an egr delete?
    A custom tune can fix what you lose from the egr delete.
    I don't have one and still get 30-32 mpgs freeway.
  9. #9 Re: what are the benefits of an egr delete?
    I deleted my egr and saw no difference in gas mileage at all.
  10. #10 Re: what are the benefits of an egr delete?
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    My thinking and you can take it with a grain of salt... I deleted my EGR and had it tuned out of my PCM. Why:
    1) Cleans up the engine bay a lot
    2) Opens up area to work to change plugs LOL
    3) MPG are not noticed in around town driving.. you might lose 2-3 MPG highway driving
    4) And most important to me, I now do NOT have hot exhaust running through my intake into my cyl's...
    I am trying to keep the air as cool as possible so my thinking was, remove EGR, no more hot exhaust gas.. Now is my thinking right, who knows.. LOL But made sense, and looks better..
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  11. #11 Re: what are the benefits of an egr delete?
    Nov 2011
    NY
    Actually, the HOT exhaust gases (inert) COOL the combustion... But I did it to get rid of the residue it leaves in there...
  12. #12 Re: what are the benefits of an egr delete?
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    This guy has no EGR.
    Never saw a difference in MPGs.
  13. #13 Re: what are the benefits of an egr delete?
    SWPA
    I deleted EGR on my Stealth and MPG went UP.
  14. #14 Re: what are the benefits of an egr delete?
    The EGR is not always open, it only opens at certain times based on speed/rpms/airflow etc etc. So the only time the hot gases that help cool the combustion is when cruising around like on a freeway.
  15. #15 Re: what are the benefits of an egr delete?
    Nov 2009
    Tennessee
    Now I know, still don't have it and not putting it back.. LOL
  16. #16 Re: what are the benefits of an egr delete?
    Mokena IL
    EGR is suppose to help reduce Nox emissions. That is the main goal but it also helps in gaining 1-2 MPG and really only opens during cruising. i think 04+ GPs' benefit most by deleting it because of the Throttle by wire. I have seen several GP's have hard start no start issues and ended up having to clean out the throttle body with carb cleaner and a rag as a fix. The egr inlet in the intake is right after the THrottle body and coats it with carbon build up bad.
  1. Benefits of ant EGR delete ?
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 05-27-2012, 05:39 PM
  2. benefits of blocked egr?
    By 99prixgt in forum General Tech Discussion
    Last Post: 04-12-2009, 04:03 PM
  3. ? benefits of intake?
    By DesQ27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-19-2008, 05:18 PM
  4. Benefits of Blocked SC case to L26/L36 UIM .
    By oldsman105 in forum Turbo
    Last Post: 06-17-2008, 03:36 AM
  5. EGR Delete Benefits/Discussion
    By TyroElite in forum General Tech Discussion
    Last Post: 01-05-2008, 04:39 PM
