Thread: Gen V Swap, PCV question. Did I do it right?
Results 1 to 19 of 19
  1. #1 Gen V Swap, PCV question. Did I do it right?
    Donating Users akarana23's Avatar
    West Bloomfield, MI
    This may be a dumb question but I figured I'd ask just to be on the safe side. Just recently I swapped over to a Gen V setup on my 2000, and was wondering if the PCV was setup correctly by me. I did plenty of reading and by what I've found it says to put a hose on the nipple on the back of the Gen V by the EVAP sensor, and run that hose to the air intake, between the throttle butterfly and MAF sensor.
    "2) Second modification you must make is the PCV system extension. If you look at the Gen V, and locate the EVAP sensor, look to the right, and you'll see a small nipple. This is part of your PCV system, this MUST be utilized, or you WILL have a vacuum leak!! Below are your choices:
    • You can run a tube from this nipple, to the air intake, this inlet must be located behind the MAF sensor, but before yourthrottle butterfly. In the LS1/Northstar setups, this is easily done by threading a tube into the air intake between theMAF sensor and the throttle body. On the L67 throttle body, it’s a little more involved. There is a brass plug on the bottom of the l67 tb, drill out the plug then tap it."
    ^That's on the Gen V swap thread, that I read up on before doing all this.
    Here's some pictures to show you guys what I did
    Thanks in advanced for any help.
  2. #2 Re: Gen V Swap, PCV question. Did I do it right?
    I live here. TLSheff's Avatar
    I'm not for sure on the line because I haven't ran a GenV myself so
    but is that JB Weld on the TB? or something else?
  3. #3 Re: Gen V Swap, PCV question. Did I do it right?
    West Bloomfield, MI
    Yes it is, to block the EVAP ports on it. But that's only temporary, I'll be filling it much more professionally than that tonight lol
  4. #4 Re: Gen V Swap, PCV question. Did I do it right?
    that is correct sir... have you done the front aswell?
  5. #5 Re: Gen V Swap, PCV question. Did I do it right?
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    *as he looks around* da front........
    LOL
    I used that same custom coupler from MAF to N* also..
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  6. #6 Re: Gen V Swap, PCV question. Did I do it right?
    whoops brain fart you dont have to do anything to the front unless its going on an ICer... my bad
  7. #7 Re: Gen V Swap, PCV question. Did I do it right?
    West Bloomfield, MI
    Thank you guys a whole bunch for you insight
  8. #8 Re: Gen V Swap, PCV question. Did I do it right?
    Correct on the PCV, however the hole you could have gone into vs the intake tubing is shown in this pic. That is routed right before the TB butterfly. Sticking up on the left.
    Rotated down to work better and hooked up to PCV nipple on charger
    Almost can't see the hose in this pic looking at the intake
    Cleaner pic
    It looks like the holes that you closed up on the bottom are the coolant heat tubes, not evap. If you would like to run evap though...use your stock evap and drill/tap that plate you used for a blockoff. Then hook to the nipple you put in it.
  9. #9 Re: Gen V Swap, PCV question. Did I do it right?
    West Bloomfield, MI
    Very clean looking indeed, Ill have some tucking to do myself, but isn't that a N* TB? I'm on an LS1 TB, so unfortunately I don't have that tube that comes up on the left
  10. #10 Re: Gen V Swap, PCV question. Did I do it right?
    Ok...I tried.. lol Made the assumption and ...... wait for it.. I was wrong once again. It'll happen in the future, it's happened in the past. I lost track of thought after you said nipple.
  11. #11 Re: Gen V Swap, PCV question. Did I do it right?
    West Bloomfield, MI
    LOL sorry to throw you off like that I wouldn't say you were wrong, I won't pick on you too much
    However, I do like how clean the N* looks with the PCV on there. Can't even tell.
  12. #12 Re: Gen V Swap, PCV question. Did I do it right?
    haha.... nipple...
  13. #13 Re: Gen V Swap, PCV question. Did I do it right?
    That was the first build for my car. Hence why it looks so nice. No build in my car ever looked that pretty again.
  14. #14 Re: Gen V Swap, PCV question. Did I do it right?
    GTP Level Member buickman104's Avatar
    NYC
    Sorry to thread jack, but my question pertains to this thread. From what I understand both pcv and EVAP are after the maf, but the PCV is pre throttle butterfly and evap is post with a nipple drilled and tapped into the adapter plate? Is that correct?
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  15. #15 Re: Gen V Swap, PCV question. Did I do it right?
    Correct.. unless you decide to put it into the Gen V evap hole. Then you don't have to drill your adapter
  16. #16 Re: Gen V Swap, PCV question. Did I do it right?
    NYC
    Put what into the gen 5 evap hole?
  17. #17 Re: Gen V Swap, PCV question. Did I do it right?
    If you reread this thread, you'll see that I suggest putting a fitting into the block off plate on the evap hole of the Gen V. Or if using a stock TB, you can use the stock Gen V evap.
  18. #18 Re: Gen V Swap, PCV question. Did I do it right?
    NYC
    Understood! Thanks for the help!
  19. #19 Re: Gen V Swap, PCV question. Did I do it right?
    Jan 2013
    Anderson SC
    So my N* TB does not have the nipple for the PCV, so can I tap my EVAP hole and plug it into that?
  1. DIC Swap Question
    By Tremayne0126 in forum Audio, Security & Visual Electronics
    Last Post: 12-21-2022, 07:35 AM
  2. DIC swap question..
    By selym17 in forum Audio, Security & Visual Electronics
    Last Post: 04-13-2012, 12:15 PM
  3. Gen V Swap Question
    By Black18Ice in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-31-2011, 05:42 PM
  4. Top Swap'n Question
    By BillBoost37 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2011, 08:06 AM
  5. another top swap question
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-20-2009, 12:59 PM
