Thread: does anyone know how the timing marks on the chain line up?
Results 1 to 11 of 11
  1. #1 does anyone know how the timing marks on the chain line up?
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    im putting my cam in and i cant seem to find out how the timing marks are supposed to be lined up?
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  2. #2 Re: does anyone know how the timing marks on the chain line up?
    mi
    lol, step away from the car
    fyi dot to dot
  3. #3 Re: does anyone know how the timing marks on the chain line up?
    Like this
  4. #4 Re: does anyone know how the timing marks on the chain line up?
    SE Level Member sco77's Avatar
    MD
    Align the dots for balance shaft, then align the dots for the crank and cam sprockets.. It will be very obvious if this is off even by 1 chain link or 1 gear.
    98 GTP - Retired
    86 Fiero GT - L67 | VS Cam | Polished GenV | Headers to 3" Catback to dual/dual Tips | 42.5# | N*
  5. #5 Re: does anyone know how the timing marks on the chain line up?
    I live here. DirtDog's Avatar
    Jun 2012
    Quote Originally Posted by siLversLeigh View Post
    fyi dot to dot
    We all gotta learn sometime...best time to learn is while doing the work
  6. #6 Re: does anyone know how the timing marks on the chain line up?
    Sep 2011
    palm harbor florida
    fyi dot to dot
    haha real funny im just making sure because on some other cars the dots either go up in the same direction or they go as close together as possible.
  7. #7 Re: does anyone know how the timing marks on the chain line up?
    Sep 2011
    palm harbor florida
    Quote Originally Posted by marines542 View Post
    ive dont this plenty of times before i just usually looked up the timing marks or called the dealer... i cant seem to find crap on a 3800
  8. #8 Re: does anyone know how the timing marks on the chain line up?
    Quote Originally Posted by Doug 97 gtp View Post
    Timing chains, you line up the dots.
    A timing belt car like a DOHC type vehicle then sometimes the dots need to be straight up.
  9. #9 Re: does anyone know how the timing marks on the chain line up?
    Mokena IL
    Get all DataDIY subscription it has all the Manufacture specs and full tear down and rebuild steps too. That is what i used. It is $16 a year.
  10. #10 Re: does anyone know how the timing marks on the chain line up?
    Sep 2011
    palm harbor florida
    ill look into that
  11. #11 Re: does anyone know how the timing marks on the chain line up?
    Something that most don't do and should is to set the timing marks dead on before pulling a chain. Then put your new set on, let's say it's a rollmaster with multiple keyholes for the crank. Easy check Put the old sproket on to test that the crank dot is straight up and check it after install since there's enough key to put it back on the end.
  1. hot do i line up a vs cam with a stock timing chain gear?
    By Doug 97 gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-24-2013, 03:18 PM
  2. double timing vs stock timing chain
    By Dam20735 in forum General Tech Discussion
    Last Post: 05-24-2013, 12:53 PM
  3. timing chain
    By pure in forum General Tech Discussion
    Last Post: 08-16-2009, 02:00 PM
  4. Which timing chain to get.
    By PWNED in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-20-2008, 09:01 AM
  5. Which timing chain?
    By whitcomb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-01-2008, 04:49 PM
