Thread: engine install with rear header or wihtout?
Results 1 to 6 of 6
  1. #1 engine install with rear header or wihtout?
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    i was noticing that the engine bracket in the back goes on after the rear header is on... now I was wondering if you can drop the motor in with the rear header or do I put the header on after the engine is dropped in?
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  2. #2 Re: engine install with rear header or wihtout?
    GTP Level Member tms8582's Avatar
    Washington Michigan
    Just put the header in place first then drop the engine in. Pretty sure its about impossible to get a rear header in from top when the motor is in. I took the engine bracket off the motor after it was in the cradle. Just keep it (both of them) in your tool box in case you pull the motor in the future.
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  3. #3 Re: engine install with rear header or wihtout?
    Washington Michigan
    In fact I'd leave off the front header too. Again it's easy to bolt up after the motor is in.
  4. #4 Re: engine install with rear header or wihtout?
    Just set the rear header in place in the car and it'll save you a lot of headaches.
  5. #5 Re: engine install with rear header or wihtout?
    Sep 2011
    palm harbor florida
    ok thanks guys
  6. #6 Re: engine install with rear header or wihtout?
    SE Level Member sco77's Avatar
    MD
    It's possible to install the lift brackets with header part off, you just have to put in a spacer (like a washer stack) on the bolts.
    98 GTP - Retired
    86 Fiero GT - L67 | VS Cam | Polished GenV | Headers to 3" Catback to dual/dual Tips | 42.5# | N*
  1. TOG header install
    By 2001goldGTP in forum General Tech Discussion
    Last Post: 12-16-2010, 11:17 AM
  2. Header Install
    By chrisgsx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2010, 05:22 PM
  3. SS intercooler and header install = engine codes
    By rascal in forum General Tech Discussion
    Last Post: 09-01-2009, 08:41 PM
  4. my header install needs help
    By gtphayes in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2009, 04:57 PM
  5. OBX Header Install is Done!!
    By Uno99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2009, 12:43 PM
