Thread: Thick film inside SC
Results 1 to 2 of 2
  1. #1 Thick film inside SC
    Johnstown, NY
    In lieu of this thread, I decided to make a thread of my own to address an issue I have. http://www.grandprixforums.net/curio...pvc-78886.html
    Inside my SC behind the throttle body, there is a thick black film which I believe to be oil. I think the PCV is to blame, but it does still rattle. The film is roughly 3/4-1mm thick, covering the entire surface area up to the rotor pack. Is this film hindering my airflow? or is there a way to clean it all out that doesnt damage the rotor pack or cause chunks of this stuff to get into the LIM? Or is my only real course of action to pull off the SC and hot tank it? (or similar process, as I know the chemical bath it's dropped into would damage aluminum) Obviously I would port the supercharger if I had to do that.
    Actually come to think of it, it seems like the same black soot you get on the inside of exhaust pipe. Could the EGR be bad? I dont have a CEL, but I'm not trusting that because I've run without the maf for a 20 mile trip and rear o2 sensor has been disconnected since the motor was installed and the lights still not on.
    98 Red Coupe Grand Prix GTP : 180* T-stat, U-Bend delete, NGK TR55's, SLP Catback
    My Ride: http://www.grandprixforums.net/jevik...upe-73301.html
    A must read for modding: http://www.grandprixforums.net/safel...0-a-67580.html
  2. #2 Re: Thick film inside SC
    It's mostly from the EGR, but pcv too.... pull pack, tape over bearings and you can clean it. Do not clean inside the rotor housing area...that build up helps seal the rotors to the case.
  1. Lens Overlay film.. Ever use it?
    By blackgtp95 in forum Visual/Body Modifications
    Last Post: 05-06-2013, 10:22 AM
  2. Protective car wrap/film??
    By David99GTP in forum Off Topic Discussion
    Last Post: 08-04-2008, 07:09 AM
  3. Film on headlights
    By green/blue05GT in forum Visual/Body Modifications
    Last Post: 07-16-2008, 11:50 AM
