Thread: Time to order some parts...
Results 1 to 19 of 19
  1. #1 Time to order some parts...
    Aug 2008
    SoCAL
    Hey all. I need a little positivity before ordering some stuff.
    I blew my head gasket a little over a year ago, so instead of fighting with the current motor I went out and bought one from the junk yard. Running when removed. Here is the list I wanna put on it. I want this done quickly, so here it goes. After reading through the site for weeks here's what I came up with.
    1) Intercooler
    2) Cooler plugs. NGK TR6?
    3) Cooler thermostat. 160*?
    4) 1.9 rockers w/valve springs
    5) 3.25 pulley (interchangable). i was told 3.1 would work with this setup, but not real sure.
    6) headers, downpipe...
    7) CAI
    8) ? bigger injectors ? 42.5#
    9) A little port/ polish intake and S/C
    10) A tune
    I don't want to tear the whole engine down, but I do want a little bit balls when I put it back in. I'm trying to keep it simple, reliable and fun.
    Any suggestions to what I have planned is welcomed!!
    Ed
  2. #2 Re: Time to order some parts...
    Skip the 160, you never need to have one colder than 180.
    Go with 60lb hr injectors, seems getting 100% correct injector data with the 42.5 is hard.
    Just build a "cai" for like 30-40 bucks instead of paying big money for a name.
  3. #3 Re: Time to order some parts...
    Aug 2008
    SoCAL
    Great. Thanks for the advice.
    Ed
  4. #4 Re: Time to order some parts...
    GT Level Member mkyota1's Avatar
    Daytona, florida
    While the engine is out I would really consider a cam instead of rockers. Not alot more money for a lot more gain.
  5. #5 Re: Time to order some parts...
    Aug 2008
    SoCAL
    Quote Originally Posted by mkyota1 View Post
    I was going the rocker route because I have never put a cam in and have no idea what i would be doing. Most other stuff I can do, but I'm not familiar with internals...
    What cam do you recommend?
    Ed
  6. #6 Re: Time to order some parts...
    Cam is really easy if the motor is out already
  7. #7 Re: Time to order some parts...
    ^ that ^
    Ant it's pretty easy to install from the wheel well as well
    04 Comp G.
  8. #8 Re: Time to order some parts...
    May 2008
    Schuyler, NE
    LOL....what?
    I would also cam it while the motor is out. Super easy when you have the motor on a stand. But, keep in mind that you'll be making lots of power with a cam and intercooler, which will be hard on the transmission.
  9. #9 Re: Time to order some parts...
    Aug 2008
    SoCAL
    Thats why I got this
    Ok, this always happens...
    So I should go the bigger injectors then 42.5?
    180* thermostat
    A cam instead of rockers?
    ---\ This will require new springs.
    ---\ What cam - VS?
    --The cam will be about $550 and rockers around $300. Is it REALLY worth the extra $250-$300??
    I had a budget of $4k. The motor cost me a little under $800. So that leaves me around $3200
    Cam and kit - $550
    IC, fuel rails and intake work, etc.. - $1500. Unless I can find it used.
    Pulley System - $100
    Injectors - $250
    CAI - $50
    All this is about $3250 (+ or -)
    I'm still gonna need a fuel pump and some minor stuff along the way i'm sure.
    All this sound right?
    Ed
  10. #10 Re: Time to order some parts...
    You'll need a 99+ alternator bracket
  11. #11 Re: Time to order some parts...
    Daytona, florida
    Quote Originally Posted by getsumbaby View Post
    Ed
    It depends what you are looking for out of the cam. I just ordered everything to put a VS cam in my car to replace my 1.9 rockers. It seems to make good power down low and in the mid-range. I have heard it referred to as a good "street cam" with lots of usable power. The XP cam makes a little more power up top but not as strong down low. The XP does have a nice lopey idle that almost made me go with it. It requires at least 105 lb springs and modded retainers from what I hear. You can get away with l76 springs which are cheaper and regular ls style retainers with the VS. Some get away running on all stock valvetrain but I would advise against it. These are just some of the offerings from zzp there are lots of other options out there.
    With the engine out it really is an easy swap.
  12. #12 Re: Time to order some parts...
    Aug 2008
    SoCAL
    Ok, thank you. I'll pull it off my other motor.
  13. #13 Re: Time to order some parts...
    Aug 2008
    SoCAL
    Yeah, from what I read the VS cam is what i'm looking for. The cam, pulley and the IC should really wake this car up and turn it into a beast! Now that 'm clear on what I need I can order some goodies
    Off to get a crappy Chilton. It's better than nothing!
  14. #14 Re: Time to order some parts...
    LOL....what?
    looooooooooooooooooooollllllllllllllllllllllllllll
    I guess most people don't care about having correct numbers for injectors, just like everyone that runs pos lucas injectors.
  15. #15 Re: Time to order some parts...
    gardner,mass
    Search around the for sale section. You can get alot more for alot less. If it was me ide do this.
    Spectra filter on tb $45
    180 tstat
    autolite 103-104s
    mps 3.1-3.2
    sd headers(there is a set on here for 200 right now)
    xp cam
    105# springs and modded retainers
    fresh chain/tensioner
    obv lim coolant elbows water pump ect while your at it if it hasnt been done.
    paint :P
    60lb injectors
    You can probly find a ic setup on here for pretty cheap 800-1000$
    There is a guy that sells fuel pumps in the for sale section for cheap(forget his name)
    transgo shift kit will help keep your tranny alive alot longer befor you can get a rebuild, but even with that you are going to have serious issues pushing this much power. You can probly get all this stuff for 2000. They sell performance rebuild kits on triple edge for like 800 bucks.
    So your looking at about 2800-3200
    Edit: Forgot about an aeroforce and wideband if you dont have already. And you can probly find someone on here in your area to tune for a pretty good price.
    Also if you do rebuild your trans a few of us have a rebuild manual to help you out. Its really not all that hard. Just alot of stuff to keep track of, but if you take your time and mark your bolts and keep everything in order on a couple tables its really not all that bad.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  16. #16 Re: Time to order some parts...
    Aug 2008
    SoCAL
    Quote Originally Posted by Ginseng View Post
    180 tstat
    autolite 103-104s
    mps 3.1-3.2
    xp cam
    paint :P
    60lb injectors
    Thanks for the info.
    I just bought the VS cam from OneSlowMonte. I was told I can run the stock springs with the VS cam. So that will save a little bit of $$$. I thought i made a deal with someone on the site for a IC but it was sold under me... Gasket kit, Coolant elbows and chain/ tensioner ordered. Still need to get the water pump, injectors, fuel pump, aeroforce and wideband. And need to figure out the exhaust.
    I live in CA so I have to watch the exhaust so it will still pass smog (i hate CA). 3.1 is what I'm looking to get. I think it will be perfect with the VS and the IC.
    Now if I can't find a good used IC kit, is it worth getting the Phenolic IC from this site? W Body store has a pretty good price on their intire kit.
  17. #17 Re: Time to order some parts...
    GTP Level Member tms8582's Avatar
    Washington Michigan
    Sounds like people have you on the right track so far but a few things to consider (I just did similar build and ended up sending motor to machine shop due to cam bearing wear)...
    If you go with a cam check the cam bearings for wear. Just about all these motors have lower intakes go back which can leak down on cam causing bearing wear. This changes your whole build and time line. Trust me! If you go with a stage 1 cam or similar you need 105 springs or 90 at least. Don't be cheap and use stock springs. Might as well do lifters too. Push rods not a bad idea either. You may need smaller retainers with the bigger cam also... With stronger springs you will want stronger timing chain... might as well do oil pump while your in there... If you want higher rpms you will need the stiffer springs.
    This stuff gets expensive real quick and plan on spending much more that you figure because you will always need a few more parts here and there. Sensors, gaskets, O-Rings, hoses, clamps, fluids etc... My thinking on my motor was to sure up the bottom end while it was out of the car.
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  18. #18 Re: Time to order some parts...
    Mar 2013
    Colorado - USA
    I just did a low-miles L32 swap complete with an Intense S1X cam. The heads have a decent port job and Crow Cams 105's with all the trimmings. Before this setup, I had 1.9:1 rockers on the same heads with stock springs etc. and loved it. It was programmed to upshift at 6000 rpms and I never once had a problem. And it was a damn fast car too. 0-60 in six seconds flat and 14.20's at the track in 90 degree heat at 4500 feet elevation with zero track prep.
    After the cam it's been transformed. It's definitely faster - no doubt about it. Probably an easy 13 second car now at 7000 ft elevation. It shifts at 6500 now. I've had it as high as 6700 rpm and it didn't miss a lick with the new springs. I'm keeping the shifts right at 6500 rpm because that is the maximum shift speed specified in my 4T65E manuals. That puts me at 60 MPH on the 1-2 and near 100 on the 2-3.
    I used stock injectors both before and after the swap but they were running above 18 msec after the cam and 15-17 before. My stock o-ring disks were deteriorating so I swapped them for Siemens 60 pounders from ZZP. they had the best price I could find. They were seriously easy to tune in. I just took the stock IFR table and cut it to exactly 60% of original. Instantly I had single digit fuel trims and a smooth idle to boot even at the stock desired RPM.
    If I knew then - what I know now...I would have gone with an even more aggressive camshaft. I chose the S1X because I judged it to be more aggressive than the ZZP VS by the published specs. This S1X cam has a strong top-end and I don't believe that I gave up any bottom end grunt or driveability in the exchange. I still get about 19 MPG average driving just like before the cam. Highway mileage seems good too. But I think my setup could easily support a stage II camshaft and it would better fit the character of the car.
    E85 L32 S1X Heads 105#Crow Springs LQ4 2k+NStarTB Deka 60# Gen1 SLP Headers Stock Plugs
    19 deg GFS and ZERO KR@14 PSI <10% LTFT
    GMPP Struts/Springs SLP Sway Bars Z06 Brakes
  19. #19 Re: Time to order some parts...
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    You can run stock injectors down to a 3.3 but if u go lower then u need 42.5s
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  1. Got a few parts that I'm having a difficult time locating... kinda
    By RALM in forum Shops and Community Heroes
    Last Post: 08-26-2012, 06:13 PM
  2. Long time reader, first time poster.
    By KeithGTP03 in forum Introductions/Noob Questions
    Last Post: 01-27-2011, 12:55 AM
  3. long time visitor first time poster
    By max98 in forum Introductions/Noob Questions
    Last Post: 05-20-2010, 10:50 PM
  4. Need advice on which parts to order
    By benner in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-18-2010, 12:00 AM
  5. first time post long time car owner
    By penstar66 in forum Introductions/Noob Questions
    Last Post: 02-11-2009, 03:54 AM
