Thread: Valve springs to go with an XP
Results 1 to 7 of 7
  1. #1 Valve springs to go with an XP
    GT Level Member WolvesSoulZ's Avatar
    Québec
    Sup, got a question here.
    So I'm buying stuff for a cam swap on my comp-g and was wondering exactly what springs and retainers to buy.
    I was thinking #105 Springs and modded retainers from zzp, but are the modded retainers needed or can normal ls styled spring retainers work? I'm a bit puzzled there.
    Note that this build is going to be used on stock heads.
    While I am there, anyone got a full list of what's needed for a cam install? I've got one made up on an excel sheet but to double check. I'm also gonna change the head gaskets.
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  2. #2 Re: Valve springs to go with an XP
    May 2008
    Schuyler, NE
    You will need the modded retainers for extra clearance since the XP has quite a bit of lift. I would also recommend getting Viton valve seals.
    As far as parts, you will need:
    Timing Chain
    Timing Chain Tensioner
    Cam Bolt
    Front cover gasket
    LIM gaskets
    S/C gasket
    Valve cover gaskets
    New rocker arm bolts
    RTV
    6 new injector o-rings are recommended
    I always recommend enough oil and filters for at least 2 oil changes
    Antifreeze
    Crank bolt is recommended to be replaced, but I have reused a lot of them
    That's off the top of my head. I feel like I'm missing something.
  3. #3 Re: Valve springs to go with an XP
    Add in a TB gasket, you may as well clean it while you are there.
    Brake cleaner (for gasket surfaces once they are gasket free)
    TB cleaner
  4. #4 Re: Valve springs to go with an XP
    Portland Oregon
    105's will work just fine as long as you're not going to rev it past 6300-6500. They are right, modded retainers are necessary due to doing install height being different and clearance issues
  5. #5 Re: Valve springs to go with an XP
    Québec
    So I suppose this looks good ?
    I had already planned for 3 oil changes ; Already planned to clean the TB and already got the gasket for it. Shifts are probably gonna be set at 6200 rpm.
    (Oh and injector o-rings, got a box full of em here.)
    Not so bad, full cam install, just a wee bit above one paycheck. Total price will probably go down as the parts comes in as I buy on rebate / source them cheaper(As in price, not quality) if possible.
  6. #6 Re: Valve springs to go with an XP
    May 2008
    Schuyler, NE
    Everything looks good. But, you do know that you don't need to remove the heads, right?
  7. #7 Re: Valve springs to go with an XP
    Québec
    Yes I know.
    Just got a bhg. Or highly possible. Coolant bubbles in overflow tank after shutdown.
  1. Valve springs
    By 2000supercharged in forum General Grand Prix Discussion
    Last Post: 09-14-2012, 07:05 PM
  2. Valve Springs
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-13-2011, 07:21 PM
  3. valve springs
    By redynscire in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-08-2011, 07:32 PM
  4. valve springs
    By 99prixgt in forum General Tech Discussion
    Last Post: 05-07-2009, 10:33 PM
