Thread: High Idle
Results 1 to 8 of 8
  1. #1 High Idle
    I cant figure this one out...
    On start up, I shoot up to 2k rpms for a second and then creep down to about 1200rpm. In gear, i sit right around 1k rpms. I have played around with my target idle and it has made no difference. I checked for a vac leak and have found nothing. Unplugged the maf and again... no change. Just wanna see where to go next here as far as figuring it out (pcv/IAC maybe?) before just throwing money at it. Other than this the car runs fine it is just annoying.
    Jarred
  2. #2 Re: High Idle
    What does your tps read at idle?
  3. #3 Re: High Idle
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    IAC is a good place to start, but what bill said ^ first.
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  4. #4 Re: High Idle
    brb Ill go check...
  5. #5 Re: High Idle
    Anything over ...oh wait.. what year? Because DBW uses throttle plate for idle
  6. #6 Re: High Idle
    tbs is at 0 and the IAC is at 185 (which I think is a little high). Car is an 02 but I have a LS1 TB setup.
  7. #7 Re: High Idle
    Nebraska
    If the IAC moves at all chances are it probably works make sure it doesn't stay at 185 all the time or u need a new iac. You said u checked for vac leak did u use carb cleaner? Or eyes? Lim, t fitting under sc snout, tb gasket, vac going to your map sensor are main places to look also what is your map reading
  8. #8 Re: High Idle
    map is reading 33 KPA
  1. High idle?
    By JESSEGOTTA GP GT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-16-2012, 01:47 PM
  2. Need help with my high idle
    By GPMANE97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2010, 09:11 PM
  3. High idle; car keeps moving
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-04-2010, 04:37 PM
  4. High idle?
    By WhiteGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-15-2009, 02:14 AM
  5. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
