Thread: smoke test
Results 1 to 8 of 8
  1. #1 smoke test
    GT Level Member 01GrandPrixTURBOGT's Avatar
    Dec 2011
    Decatur
    So I blew smoke through my map hose and it came out through my throttle body. Is that supposed to do that? I also found a few more leaks up by the brake booster and boost vacuum lines on top.
  2. #2 Re: smoke test
    Texas
    Dumb question did you have the car running when you did this?
    85 Corvette
    01 TA
    03 Z06
  3. #3 Re: smoke test
    Dec 2012
    Where 4T65E's were born
    Smoke would never come out if it was running. Air (smoke) should be able to pass through the TB as far as I know since it's not a perfect seal when it's "closed". Anywhere else would be considered a vacuum leak and should be repaired.
    Sold.
  4. #4 Re: smoke test
    Texas
    Exactly why I asked
    85 Corvette
    01 TA
    03 Z06
  5. #5 Re: smoke test
    Dec 2011
    Decatur
    No car was off. But i plugged the end of the intake and smoke came out under the snout of the blower so looks like im replacing gaskets. But i do have other questions is there an o ring that goes on the egr slot by the two coolant passages? Also why would coolant be leaking from under the throttle body? The gasket looks brand new still. And do you guys put anything between the rotors and case and the snout like rtv gasket sealer. Thanks for the help.
  6. #6 Re: smoke test
    Dec 2011
    Decatur
    Bump
  7. #7 Re: smoke test
    There is no o-ring around the EGR. Only the coolant passages, it would be nice to know what year. Because that can change answers slightly.
    If you don't think the TB is leaking, Is this an internal or external leak? External.. check the little turn around cap under the TB on the LIM.
    Slide rotors into case..no sealant. Sealant only goes from rotor pack to snout.
  8. #8 Re: smoke test
    Dec 2011
    Decatur
    01GrandPrix
  1. Smoke!
    By barnettimpala in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-18-2013, 01:07 AM
  2. Smoke?
    By 07gtstock in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2012, 06:42 AM
  3. Smoke
    By ShadowSwept in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-17-2012, 02:17 PM
  4. Do you smoke?
    Last Post: 08-27-2011, 01:13 PM
  5. 1st smoke show
    By biggt in forum Off Topic Discussion
    Last Post: 10-14-2010, 11:49 PM
