Thread: Oily substance in coolant
Results 1 to 2 of 2
  1. #1 Oily substance in coolant
    SE Level Member justin10morrissey's Avatar
    Nov 2011
    Missouri
    Looked in my coolant reservoir today and it had a dark milky substance kind of like oil. Drained oil pan but no coolant in the oil. had a radiator flush done lots of gunks pulled out when a flush was done less than 6 months ago. Dexcool has been taken out of the engine since i bought it a year or so ago. Havent yet checked to see if its trans fluid. possibly an lim gasket they were supposedly replaced by the previous owner anyway the car has 140xxx mi and its a 2004 gtp. it has a hai beldan wires and a dp highflo cat which i hate bc it throws a code. i also think the cat is fouling out my plugs. Its in need of a tune but definately want to address on what the problem possibly could be any help is appreciated
  2. #2 Re: Oily substance in coolant
    Likley it's just residue from the old coolant. However .. if you had a picture of if you see it again, please get a picture.
  1. Flashing Low Coolant Light, Coolant Full, No leaks
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-12-2012, 08:25 PM
  2. oily substance on SC gasket, snout side
    By TEK310 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-29-2012, 12:06 PM
  3. Masive knocking noise and spark plug all oily
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-22-2011, 12:12 AM
  4. whats milky and oily and causes a car to just stop running
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 09-04-2010, 12:54 AM
  5. low coolant light...but not so much low coolant..?..
    By 1lilcountrygrl in forum General Tech Discussion
    Last Post: 08-08-2010, 12:29 PM
