Thread: 2 problems, 2 codes help me out..
Results 1 to 11 of 11
  1. #1 2 problems, 2 codes help me out..
    Florida
    Got the car scanned yesterday after work since out of nowhere it felt sluggish, shifting was a lil weird and speedo didnt seem accurate, like it said I was doing 55 but felt like I was at 45mph. Code 1 was p401 EGR code, I hear I can take that off and spray carb cleaner into it to clean it out which could troubleshoot it for now but would that be correct and what else could I do? Car just feels sluggish and dosent pull like it should it even sounds a bit louder but I could be paying attention to it too much. And second code was for I believe my wheel speed sensor would that be the culprit for my speedo and shifting issue? And would I be ok driving it for a few days til im off on Fri?
  2. #2 Re: 2 problems, 2 codes help me out..
    Step 1, list what that code stands for and let's learn about it together instead of guessing at the issue.
  3. #3 Re: 2 problems, 2 codes help me out..
    Florida
    Well I mentioned code 1 was p401 EGR , and the tech didn't pull up the abs code but my trac and abs light have been on since day 1 and I did get that scanned some months ago and it was some weird co18... Wheel speed sensor abs module code. Can't remember exactly but that's why I mentioned the speedo issue.
  4. #4 Re: 2 problems, 2 codes help me out..
    Ok, pretend I'm tired and lazy.. what does 401 translate to in words?
    Wait..don't pretend, I am tired and lazy.
  5. #5 Re: 2 problems, 2 codes help me out..
    The vehicle speed sensor is located on teh differential housing of the transmission. A wheel speed sensor is typically only used for ABS, it should not effect the speedometer.
  6. #6 Re: 2 problems, 2 codes help me out..
    as odd as this sounds, i had the po401 code, egr low flow, a new map sensor fixed it.
  7. #7 Re: 2 problems, 2 codes help me out..
    Oh.. 401 is the ollllllle flow one eh?
    Yeah, you have to look at what is being tested and how it's being tested. Flow is detected by the map, the map expects to see a change in intake pressure when the egr is opened, if it doesn't..it tosses this code. Which..doesn't necessarily mean anything is wrong with the EGR. It means.. the change in flow was not seen.
  8. #8 Re: 2 problems, 2 codes help me out..
    i started out with a low voltage code for the egr, changed that as you know Bill lol a week later the 401, low flow showed its face. and a evap code. changed the map and the evap purge sensors, no light for 3 weeks now.
    and my mpg went back up. as soon as the light went on, i lost 2 to 3 mpg, almost instantly on my avg mpg.
  9. #9 Re: 2 problems, 2 codes help me out..
    Florida
    So to break it down? What am I looking to do and what else could it be?besides the p0420 code that I've been had those are the only 2 codes.
  10. #10 Re: 2 problems, 2 codes help me out..
    Check your map sensor and vacuum lines.
  11. #11 Re: 2 problems, 2 codes help me out..
    pull the egr, clean the tubes, make sure they are not cracked or anything, put them back clear the code, see if it comes back, if you found a carbon blockage that was the low flow, if its all clear, try changing the map sensor.
    the other code is your cat. if its a hi flow cat, you'll need a emulator maybe.
  1. codes codes codes gotta love them!
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2012, 02:13 PM
  2. Car Codes
    By 1996pontiac in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-09-2010, 08:23 AM
  3. Got Problems with my Gp and got codes need help???
    By chitownballer8908 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-26-2009, 10:18 PM
  4. Help with SES codes
    By kstanko in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-04-2009, 09:27 AM
  5. 3 codes, what could it be?
    By spidamanSS in forum General Tech Discussion
    Last Post: 08-19-2008, 02:24 AM
