Thread: Is this ZZP Oil Volume Kit worth it?
Results 1 to 16 of 16
  1. #1 Is this ZZP Oil Volume Kit worth it?
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    ZZPerformance - Oil Volume Kit #ZZ-OILVKIT
    I was thinking about getting this.. Just want some opinions.
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  2. #2 Re: Is this ZZP Oil Volume Kit worth it?
    I'm pretty sure the real issue the very poor casting of the stock unit on 97-03 cars.
    If you going to use that L26 you bought, it already is better than a 97-03 motor, so you would not need it.
  3. #3 Re: Is this ZZP Oil Volume Kit worth it?
    Omaha, NE
    What cam said. Series 3 ftw!
  4. #4 Re: Is this ZZP Oil Volume Kit worth it?
    Apr 2012
    Middletown DE
    Ok
    The block from my 2005 GP was stamped the Series 2 stamp, but the cars production date was 9/04 which is normal from what I have read.
    I have this L26 block from a 2005 Buick Lacrosse and the stamp says 3800 Series.... and there is no number... is that normal?
    1993 Oldmobile 88
  5. #5 Re: Is this ZZP Oil Volume Kit worth it?
    My 05 L26 says Series II on it.
  6. #6 Re: Is this ZZP Oil Volume Kit worth it?
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    My '07 L26 just said 3800, no series. But I didn't may much attention, I was to busy looking at my new aluminum oil pan suckd on the bottom of it... LOL
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  7. #7 Re: Is this ZZP Oil Volume Kit worth it?
    Omaha, NE
    The stamp broke at some point. No big deal.
  8. #8 Re: Is this ZZP Oil Volume Kit worth it?
    That's just the spring out of a 04+ isn't it?
  9. #9 Re: Is this ZZP Oil Volume Kit worth it?
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    That's what I thought...
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  10. #10 Re: Is this ZZP Oil Volume Kit worth it?
    GT Level Member DJNight2k's Avatar
    Lorain, OH
    according to GM the spring is the same part number for both series 2 and 3. I looked into this at work.
  11. #11 Re: Is this ZZP Oil Volume Kit worth it?
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    Is that a real answer? If you're being sarcastic then I get it but sometimes I wonder how people figure out information on these websites. Kinda like a he said she said thing.
  12. #12 Re: Is this ZZP Oil Volume Kit worth it?
    SE Level Member pman64's Avatar
    Central Illinois
    I bought one when I did my build 2 years ago. It's basically the stock spring and plunger with a washer under it to increase spring(oil) pressure. I did notice a increase in oil pressure. Holds 20lbs/in at idle
  13. #13 Re: Is this ZZP Oil Volume Kit worth it?
    May 2008
    Schuyler, NE
    Actually guys, Ford stole the stamp from GM. That's why it disappeared from the block after certain years.
  14. #14 Re: Is this ZZP Oil Volume Kit worth it?
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    Buy a m6 (1/4) washer and put it in the plunger before the spring. Volla oil pressure increased.
    97 Bonneville SE Not so much a 97 anymore
  15. #15 Re: Is this ZZP Oil Volume Kit worth it?
    Feb 2010
    Oklahoma City, OK
    It's not a stamp, it's raised up so it's part of the mold they use to cast the blocks.
    From an 06 L32:
  16. #16 Re: Is this ZZP Oil Volume Kit worth it?
    Apr 2012
    Middletown DE
    Right now with a kit I got from rockauto I see 30-40 psi at idle and almost 90 at WOT.
    The kit had the oil pump, spring, and plunger.
    1993 Oldmobile 88
  1. Oil volume kit?
    By PontiacL32 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-03-2012, 12:58 PM
  2. Oil volume kit. anyone using one?
    By DJNight2k in forum Turbo
    Last Post: 11-20-2012, 02:22 PM
  3. oil volume kit.from zzp?
    By TEK310 in forum General Tech Discussion
    Last Post: 03-13-2012, 05:41 PM
  4. One Volume only
    By emmi in forum Audio, Security & Visual Electronics
    Last Post: 04-15-2010, 09:21 AM
  5. Sub Craps Out When Volume Goes Up
    By hondo in forum Audio, Security & Visual Electronics
    Last Post: 02-08-2010, 10:56 PM
