Thread: Built motor is blown (video) and buying a L26 for now and moving all my things to it
Results 21 to 40 of 53
  1. #21 Re: SO I put 300 miles on the new engine and now it has a knock/tap sound, kill me.
    Quote Originally Posted by buck531 View Post
    And this is why a stock bottom end is better than building a motor...
    That sucks.
    Only if you neglect it and didn't do it right.
    If it was totally built from a bare block...and the mains weren't line bored...then lol, yup. 300~ mile miracle.
  2. #22 Re: SO I put 300 miles on the new engine and now it has a knock/tap sound, kill me.
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    Also I just remembered while turning the crank pulley to do the flex plate bolts that the engine jammed and we had to use a huge breaker bar to make it start spinning again
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  3. #23 Re: SO I put 300 miles on the new engine and now it has a knock/tap sound, kill me.
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    Quote Originally Posted by acidcrashdburnd View Post
    Hindsight is always 20/20.
    Hope everything turns out for ya.
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
  4. #24 Re: SO I put 300 miles on the new engine and now it has a knock/tap sound, kill me.
    GT Level Member Knightmare's Avatar
    Jul 2011
    Frederica, DE
    Man this sucks! I hope it all works out for ya man....hate to see stuff like this
    Sent from my GT-P5113 using Tapatalk 2
  5. #25 Re: SO I put 300 miles on the new engine and now it has a knock/tap sound, kill me.
    GT Level Member ls1camino's Avatar
    Laurel, MD
    Is the machine shop going to warranty the work?
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged (T67 Turbocharger).
    2007 Chevrolet Silverado 3500 Dually: Intake, Exhaust, and Tune.
  6. #26 Re: SO I put 300 miles on the new engine and now it has a knock/tap sound, kill me.
    Apr 2012
    Middletown DE
    Quote Originally Posted by ls1camino View Post
    Ill find out may 22nd.
    1993 Oldmobile 88
  7. #27 Re: SO I put 300 miles on the new engine and now it has a knock/tap sound, kill me.
    Feb 2009
    flintnasty MI
  8. #28 Re: Built motor is blown and buying a L26 for now and moving all my things to it
    Apr 2012
    Middletown DE
    Picking up an L26 with 55k on it from a place in NJ Friday, I am moving my top end, cam, and timing chain over to the L26 taking my broken built motor to get repaired/redone. I was thinking of running a 3.3 or 3.5 pulley on this, the Gen 5 has a 3.0 on it now.
    I figured I would get the built block done store it in my basement beat up on the L26 for a summer and swap in my new junk next April
    1993 Oldmobile 88
  9. #29 Re: Built motor is blown and buying a L26 for now and moving all my things to it
    Jul 2012
    sounds like a plan
  10. #30 Re: Built motor is blown and buying a L26 for now and moving all my things to it
    Laurel, MD
    Sell me your broken short block.
  11. #31 Re: Built motor is blown and buying a L26 for now and moving all my things to it
    Apr 2012
    Middletown DE
    ill sell you everything under the hood including the trans and another crank for $2000 obo if you provide a WORKING trans and come help me install the trans and engine in the car so I can trade it in.
    I get more and more annoyed with this car as the hours go by
    1993 Oldmobile 88
  12. #32 Re: Built motor is blown and buying a L26 for now and moving all my things to it
    Jul 2012
    it's part of the challenge Justin. When it's finally done, you'll look back and laugh about it. If it were easy, we would be ricers
  13. #33 Re: Built motor is blown and buying a L26 for now and moving all my things to it
    Apr 2012
    Middletown DE
    Is there anything I need to do with this JY engine? can I just bolt all my crap up/in to it? I only want to remove the heads ans nothing else if I can get away with that.
    1993 Oldmobile 88
  14. #34 Re: Built motor is blown and buying a L26 for now and moving all my things to it
    Apr 2012
    Middletown DE
    oh and this is an ACTUAL PART of the conversation I had with one of the owners of the machine shop.
    MS:"is this the car that was going to have a blower on it?"
    Me: "yes"
    MS: mmmmmmmmmmmmmhhhhhhhhhhhmmmmmmm, and you didn't beat on it?
    Me: "NO."
    MS: "and you say you put 300 miles on it in just 4 days?
    Me: "YES WHY DOES IT MATTER THE NUMBER OF DAYS vs MILES?!"
    MS: "I'll have peter call you tomorrow we need to discuss about this."
    1993 Oldmobile 88
  15. #35 Re: Built motor is blown and buying a L26 for now and moving all my things to it
    Yup sounds like a easy excuse not to redo the work. Shouldn't matter how many miles you put on it in X amount of days as long as you weren't beating on it.
    04 Comp G.
  16. #36 Re: Built motor is blown and buying a L26 for now and moving all my things to it
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Yes, everything will bolt up to your L26. I just did it in a 99 GT. L26 bottom, Gen III top swap, cam... Easy peasy
    Cam will require you to pull the timing cover, if you swap cam.
    Sorry to hear about your motor... I debated on getting my L36 rebuilt and I about pooped myself when the machine shop told me how much... LMAO I said just do the heads, I'll make a coffee table for the garage out of the block...
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  17. #37 Re: Built motor is blown and buying a L26 for now and moving all my things to it
    Apr 2012
    Middletown DE
    I am going to try to get a full or partial refund and just send the broken block to intense so they can tell me exactly what broke and fix it.
    1993 Oldmobile 88
  18. #38 Re: Built motor is blown and buying a L26 for now and moving all my things to it
    Apr 2012
    Middletown DE
    Quote Originally Posted by dbextreme View Post
    Thats what I was going to do as i was already top swapped but found the chipped pistons. What size pulley do you run and which cam? I have the intense stage 2 blower cam with supporting mods and I was going to run a 3.3, I have a 3.5 and 3.0 that could also be used.
    1993 Oldmobile 88
  19. #39 Re: Built motor is blown (video) and buying a L26 for now and moving all my things to
    Apr 2012
    Middletown DE
    Here is a video I got today
    1993 Oldmobile 88
  20. #40 Re: Built motor is blown and buying a L26 for now and moving all my things to it
    Nov 2009
    Tennessee
    I'm running a ported Gen III with a 3.4 pulley, XP Cam, Headers, 0 KR. Bought my L26 from a local salvage yard, very low mileage, came with the VIN to verify. So far, I'm pleased.
    http://www.grandprixforums.net/rebir...pgt-73193.html
  1. 4th engine with rod knock
    By RideWithPride in forum General Grand Prix Discussion
    Last Post: 05-26-2013, 11:34 AM
  2. Need help engine knock??
    By thomasd2010 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-28-2012, 04:34 PM
  3. New rebuilt engine rod knock sound only 75 miles broken in
    By RideWithPride in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-08-2012, 06:18 AM
  4. Engine Knock
    By tdm571 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-22-2011, 07:49 PM
  5. Hey what exactly does knock sound like ?
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 09-20-2010, 02:03 PM
