Thread: Thermostat housing sealant?
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: Thermostat housing sealant?
    GT Level Member beastin1's Avatar
    south elgin il.
    I don't know much about impalas, for some reason i thought you were supercharged....ever consider a top swap?
    2002 Galaxy Silver 4dr. GTP...supercharger heaven.
    IM ON IT!!!!!!
  2. #22 Re: Thermostat housing sealant?
    Barksdale AFB, LA
    Quote Originally Posted by beastin1 View Post
    It's already in the works.
    Impala SS's are the equivalent of a GTP. Impala LS's are the equivalent of a GT (with a minor gearing change). Base model Impalas are usually 3.4L, so just a bit above a GP SE.
    This as far as engines are concerned. Suspensions options are different. Like the SS's already have a lot of GMPP parts.
    2009 Subaru Impreza WRX STI
  3. #23 Re: Thermostat housing sealant?
    south elgin il.
    Quote Originally Posted by Sabrewings View Post
    yea a buddy of mine has the ss...it's a sweet machine....he's on here too as spidaman ss i believe...hit him up, he can give ya some pointers for when your top swap is done....
    as far as the top swap, i posted a manual on here written by another buddy of mine.... maybe it will help, good luck.
    http://www.grandprixforums.net/f17/t...lots-7763.html
    IM ON IT!!!!!!
  4. #24 Re: Thermostat housing sealant?
    Barksdale AFB, LA
    Thanks for the info, but I'm way ahead of the learning curve.
  5. #25 Re: Thermostat housing sealant?
    south elgin il.
    great...look forward to hearing of your achievements as you overcome the progress curve
    IM ON IT!!!!!!
  6. #26 Re: Thermostat housing sealant?
    Moore, Oklahoma
    I can't believe you guys have trouble getting it to seal. I bet your gasket surfaces are dirty. I wipe it down and scrape the housing side every time I change one out. Did my fourth change today, and still no issues sealing.
    I donno, I clean mine pretty damn well too. Even used scotchbrite. Its not like its rocket science. The only seal is the T-stat seal itself for the LIM and the housing. It'll either seal or it won't.
    Shawn W. Larsen
  7. #27 Re: Thermostat housing sealant?
    Donating Users PonchoDvr4Lfe's Avatar
    Feb 2008
    Kent, OH
    Agreed, Scotchbrite the LIM and housing. If all else fails, Yamabond. It is the best. Period. I have never used a commercial RTV that is better than it. IMO.
    04' GP GTP Comp G, 08' G8 GT, 10' Camaro 2SS
  8. #28 Re: Thermostat housing sealant?
    SE Level Member JHGTP's Avatar
    Nov 2010
    Sacramento
    Ok I've got the same leaking issue. At first I had the P0128 code come up and after a few hours post removal I noticed the t-stat was still wide open. So I went to Autozone and got a new t-stat and gasket, installed it but now it leaks once the engine begins heating up, and the engine QUICKLY red-lines overheat shortly after so I dare not drive it at all until this is fixed. I pulled the new one out and checked the gasket's direction but I had it installed correctly, I re-installed the old one but it still leaked. I should also mention that I thoroughly wiped the mating surface for both the housing and where the t-stat sits but it still leaks like a siv from the front of the housing once the engine heats up. Should I resort to RTV as well? Thanks for any assist...
  1. Removing alternator housing
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-06-2010, 06:14 PM
  2. M90 PCV cover sealant?
    By Sabrewings in forum General Tech Discussion
    Last Post: 10-16-2008, 02:54 PM
  3. headlight lens and housing
    By TDCRacing in forum Shops and Community Heroes
    Last Post: 08-30-2008, 01:14 PM
  4. Is painting the SC housing bad?
    Last Post: 02-15-2008, 12:30 AM
