Thread: Coolant leak behind crank
Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
  1. #21 Re: Coolant leak behind crank
    i keep getting beat out here lol. i give to much info it seems.......
    not laughing at possible cracked timing cover tho. just me and Bill.
  2. #22 Re: Coolant leak behind crank
    Yup...done it a few times.
    Crack the 4 8mm bolts on teh pully free
    Use a 13mm at 6 and 12 oclock through the pulley to lower the ps pump
    Remove pulley from pump
    Remove 4 10mm bolts from pump (one at 6 oclock)
    Remove 4 13mm bolts from pump
    Clean well
    Install new .. torque bolts to 13ft lbs
    Reinstall the rest
  3. #23 Re: Coolant leak behind crank
    but Scott..he already said..it's just a water pump
  4. #24 Re: Coolant leak behind crank
    Quote Originally Posted by JaredR215 View Post
    Correction, it's leaking from the weep hole in my water pump now. I had wiped up around that cast and it's still dry. But I put my hand under the water pump and could feel it dripping. Any write ups for this one?
    yup, take the bolts out and change it. the p/s pump needs to be un bolted, it blocks a long bolt, and the lower idler pulley needs to come off, its a 15 mm bolt, ot a t 55 torx to get it off.
    put thread sealant on the 4 long bolts, use a dry gasket, bolt it back.
    oh, big tip, with the belt still on, loosen up the 4 bolts on the w/p pulley, then take the pump off. when your done make those 4 bolts tight again, when the belt is back on, dont forget them.
    looks like this off. see the p/s pimp hanging, and the lower idler pulley is off.
    i had a few days till i put the new on, so i painted it black.
  5. #25 Re: Coolant leak behind crank
    I often use the screwdriver between a bolt and the center of the pulley to tighten/loosen the pulley bolts.
    Hmmm wonder if I have a picture of how I mod that idler piece to get a socket past it. Good call Scott... I missed the idler in my info.
  6. #26 Re: Coolant leak behind crank
    GT Level Member JaredR215's Avatar
    Jul 2011
    Cheyenne
    Bolts are out. What's the best way to pry the pump off? Don't want to damage anything
  7. #27 Re: Coolant leak behind crank
    Jul 2011
    Cheyenne
    Scratch that. It's off
  8. #28 Re: Coolant leak behind crank
    i like this guy, hes all action......ask's for some help, then hes working on it asap.
  9. #29 Re: Coolant leak behind crank
    Jul 2011
    Cheyenne
    I can't get the new pump to seal. I got it put on then found a slow leak in the back. Going to pick up some rtv for it
  10. #30 Re: Coolant leak behind crank
    take it back off, then scrape the timing cover off good with a sharp razor, im thinking you left a chunk of the old gasket behind.
    you put the thread sealant on the 4 long bolts? they can leak if not sealed.
  11. #31 Re: Coolant leak behind crank
    Jul 2011
    Cheyenne
    Well I got it. There was a small piece of the old gasket left on there.
    Thanks for the help guys. I really appreciate it
  12. #32 Re: Coolant leak behind crank
    good to hear. now go have a beer or something.
  13. #33 Re: Coolant leak behind crank
    I wasn't even here. Thanks are all for Scotty.. he's the man on the scene. Night, day... even late night!
  1. oil leak on front of crank
    By lbzclint in forum General Tech Discussion
    Last Post: 02-22-2013, 09:41 PM
  2. Coolant leak NEED HELP!
    By nickskip08 in forum Introductions/Noob Questions
    Last Post: 01-03-2013, 10:05 AM
  3. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  4. My new coolant leak
    By Taz Magister in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-02-2011, 08:31 AM
  5. Front Crank seal Leak!
    By Soeasytobefake in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2010, 11:39 PM
