Thread: 04 grand Prix gtp hesitates
Results 1 to 20 of 21
  1. #1 04 grand Prix gtp hesitates
    Apr 2013
    washington
    car hesitates when given more then half throttle before accelerating. no codes changed plugs, wires, 180 tstat, fwi. torquee shows no misfires. any other gauges I should monitor? what things could be causing this?
  2. #2 Re: 04 grand Prix gtp hesitates
    Kansas
    Hesitates how and duration of hesistation? Any issues during other times? RPMs freak at all?
    I would suggest cleaning out the throttle body as they are known to gum up, might as well clean your MAF sensor while you are there.
    Carb/Choke cleaner on the throttle body, electronic cleaner for the MAF.
  3. #3 Re: 04 grand Prix gtp hesitates
    Apr 2013
    washington
    car only hesitates for seconds and it happens when quickly giving throttle. feels like a vaccum leak but can't find Anything dissconected.,going to throw a tb spacer on it in about a week I will clean tb them. maf was cleaned when I put the fwi on with maf cleaner the inside of the tb doesn't appear to have much in it from what I can see.
  4. #4 Re: 04 grand Prix gtp hesitates
    Don't put a tb spacer on it there is no reason for it.
  5. #5 Re: 04 grand Prix gtp hesitates
    Apr 2013
    washington
    car seems to have a bunny hop while slowly accelerating only seems to studded when I have let the car sit and intake air temp gets high is it possible my maf is soaking up to much heat? how would I determine a fuel problem with a scan gauge?
  6. #6 Re: 04 grand Prix gtp hesitates
    Johnstown, NY
    The split second hesitation when you hit the gas quick is the MAF. Clean that and see if it's cured.
    98 Red Coupe Grand Prix GTP : 180* T-stat, U-Bend delete, NGK TR55's, SLP Catback
    My Ride: http://www.grandprixforums.net/jevik...upe-73301.html
    A must read for modding: http://www.grandprixforums.net/safel...0-a-67580.html
  7. #7 Re: 04 grand Prix gtp hesitates
    Apr 2013
    washington
    if that split second hesitation is the maf and it only happens when the intake is hot could it be the intake air temp is false when my fwi is sucking in cold air? I did clean the maf when I put on the fwi I'll do it again tonight and see where is takes me.
  8. #8 Re: 04 grand Prix gtp hesitates
    gardner,mass
    disconnect maf and go for a drive
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  9. #9 Re: 04 grand Prix gtp hesitates
    Apr 2013
    washington
    is there a way to diagnose maf failure or a rich or lean conditions with a scan gauge maybe an article that might help me understand them.
  10. #10 Re: 04 grand Prix gtp hesitates
    Jun 2012
    Ontario Canada
    When's the last time you changed your spark plugs/wires?
  11. #11 Re: 04 grand Prix gtp hesitates
    Apr 2013
    washington
    changed plugs 2 weeks ago
  12. #12 Re: 04 grand Prix gtp hesitates
    Apr 2013
    washington
    is the iat sensor integrated in with the maf on 04+ grand Prix? if so I think I just realized why the factory put the maf at the air box instead of the tb like 03 and below. its reporting the wrong tempature if anyone has an 04 plus with fwi chances are there maf is right over the cross over pipe and willexpierence power loss and hesitations and the iat is so slow to detect temp change right away. I'm going to relocate the maf to the 45* elbow and see what happens when the heat rises.
  13. #13 Re: 04 grand Prix gtp hesitates
    Apr 2013
    washington
    an update my car did it again today. drove home for lunch ran fine parked it for an hour started it and it was extremely.sluggish watched the scan gauge and it was getting 4* kr under moderate acceleration and almost all my timing was yanked. timing was anywhere from 3* to 5* under acceleration. intake temp was showing 70*. outside was 45* could that air temp difference cause 20* of timing pulled?
  14. #14 Re: 04 grand Prix gtp hesitates
    Mine was doing this until I fixed my intake and it hasn't done it since.
  15. #15 Re: 04 grand Prix gtp hesitates
    Apr 2013
    washington
    what was wrong with your intake?
  16. #16 Re: 04 grand Prix gtp hesitates
    Jun 2012
    Las Vegas
    Check your belt tensioners. I have the same issues and I found the S/C tensioner was bad. Possibly the water inlet tensioner also. Idle with hood open and look at the three little lines for correct set tension. Mine was not steady, but more like a wobble with alot of give. I am ordering new parts today.
  17. #17 Re: 04 grand Prix gtp hesitates
    Apr 2013
    washington
    I'll take a look at the tensioner during lunch but I still would like to know what dsmuts did to his intake to remedy his prob.
  18. #18 Re: 04 grand Prix gtp hesitates
    Apr 2013
    washington
    checked my ltft and noticed it stays anywhere from -10 to -15 think my exhaust is leaking. could this cause such drivabilty issues?
  19. #19 Re: 04 grand Prix gtp hesitates
    I spoke to soon i think it did it once today. I did have my open cone directly on my maf.
  20. #20 Re: 04 grand Prix gtp hesitates
    Apr 2013
    washington
    I can see why a hai would fix the prob cuz if you have a cai on an 04 the maf is integrated with the iat and it heat soaks and gives wrong temp while intake sucks in cold air. for a fwi and a cai we have to get a series 2 iat sensor and relocate it or put the maf somewhere cold. with you confirming a change when switching to hai it makes sence.I will fix that before moving forward with mods. did you have a cai before or stock?
  1. 99 GTP Hesitates / Dies while driving
    By tomc in forum Introductions/Noob Questions
    Last Post: 01-25-2013, 07:36 AM
  2. '01 GT - No power, won't rev above 4k, hesitates badly.
    By 10 Gauge in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-16-2012, 06:40 PM
  3. car want go and hesitates someone help
    By chevyman39452 in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-27-2012, 03:06 PM
  4. Hesitates to start
    By kking89 in forum General Tech Discussion
    Last Post: 09-09-2011, 09:34 PM
  5. Car Hesitates When Floored
    By 04GTPeeingOnU in forum General Tech Discussion
    Last Post: 07-14-2009, 07:05 AM
