Thread: P0137 code after sd header install
Results 1 to 14 of 14
  1. #1 P0137 code after sd header install
    Feb 2013
    Detroit, MI
    After I got my headers installed I'm getting the cel with the p0137 code. It says circuit low voltage bank 1 sensor 2.
    GearChatter.com :: View topic - DTC P0137 or P0157
    so this is the one after the cat in the downpipe? The cat was deleted and I thought that one was p0420, so idk what this could be. I order the o2 extension and the plugs weren't right for the rear on 04+ so I cut the plugs off n spliced them into the old set up. I made sure they were correct. There was 4 wires, a purple, a cream color, and 2 brown. I cut one brow short and one long so I made sure they were right. So idk if its something with the wires or what. Also my dad sprayed some pb blaster near the inside of the o2 n it may have gotten on it, so that's maybe my second guess. Any opinions what to do would help. Should I get a defouler or just get a new o2? I wanna make sure which o2 it is too. Thanks.
  2. #2 Re: P0137 code after sd header install
    did you splice them and then solder? If not do that.
  3. #3 Re: P0137 code after sd header install
    Nov 2012
    Madison
    After doing some reading it looks like soldering is a no-no. I mean honestly I have never done it, so sorry D if I stepped over the line.
    Some reads if you haven't already for ya Kory splicing o2 sensor wiring..good or bad? - Page 2 - Corvette Forum
  4. #4 Re: P0137 code after sd header install
    I would just buy the extension if it was me but i would think soldering would be better than butt connectors. I've never done either so i really don't know though
  5. #5 Re: P0137 code after sd header install
    Soldering is a much better connection than crimp connectors.
  6. #6 Re: P0137 code after sd header install
    Feb 2013
    Detroit, MI
    We crimped them on, I dont know if he has a soldering gun n idk even how to do it lol. I bought the $25 extension from zzp. I was so mad when I seen it didnt fit..is it the connection tho then is what you guys are thinking?
  7. #7 Re: P0137 code after sd header install
    Yeah, if you google that code.. you'll find your answer can be a crappy connection, bad sensor..etc.
  8. #8 Re: P0137 code after sd header install
    Feb 2013
    Detroit, MI
    Alright thanks bill, ill see how it is when I have time after work n update.
  9. #9 Re: P0137 code after sd header install
    Nov 2011
    NY
    Has anyone here every actually soldered those O2 wires?
    I ask, because I tried that once, found it mpossible!
    Those wires are stainless coated or something and couldn't get the solder to take no matter what I did. Soldering of course is way better than crimp, especially since many people don't use the right crimp connectors. And yes, I know how to solder... Lolz.
    But if you do it (crimp) correctly, it lasts well. On stranded wires exposed to elements like this, I'll put a little dialectric grease, crimp and heat shrink. Done!
    Idk, but the PB blaster on the sensor could've fouled it, they're pretty sensitive.
  10. #10 Re: P0137 code after sd header install
    I did successfully solder an O2 before. However it sucks majorly. The way to do the extension is to extend the factory harness side, not the O2 side. Those wires are normal and easy to solder
  11. #11 Re: P0137 code after sd header install
    Nov 2012
    Madison
    So what the snot....you ordered option C for the 02 extender from ZZP and it didn't work?? If so I'ld be raising the dead.
  12. #12 Re: P0137 code after sd header install
    Feb 2013
    Detroit, MI
    I can't remember which side I spliced into, but we did crimp. Ill have to check. No time to do today just got off work n raining.
    Quote Originally Posted by spazzz View Post
    Yeah ik i was pissed lol. I got the 16" extension I believe n I think it was option c. Idk ill have to mess with it when I have time.
    also have another code popped up. P2101 something to do with throttle body.
  13. #13 Re: P0137 code after sd header install
    I soldered mine without a problem
    04 Comp G.
  14. #14 Re: P0137 code after sd header install
    Nov 2011
    NY
    Lolz... Kewl! Yeah, I couldn't get the solder to take no matter what I did, major pita without a doubt. It was when I had a persistent P1133 code and thought the extension harness was bad, so I wanted to splice the O2 side on an extra sensor I had laying around for ****z n giggles.
    Same code stayed, found problem a month later when I found lim leaking, lol... Ggggggrrrrrrrrrr!
    All fixed now, code gone and O2 still extended, lmao! But I still have the extension for when O2 takes a holiday.
  1. header install ?'s
    By taman86 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2011, 12:16 AM
  2. TOG header install
    By 2001goldGTP in forum General Tech Discussion
    Last Post: 12-16-2010, 11:17 AM
  3. Header Install
    By chrisgsx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2010, 05:22 PM
  4. S&S Header Install
    By GRANDPRIXFOOL01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2009, 09:57 PM
  5. my header install needs help
    By gtphayes in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2009, 04:57 PM
