Thread: manual boost increase
Results 1 to 8 of 8
  1. #1 manual boost increase
    Mar 2013
    amherst
    I was told there's a screw somewhere near the s/c that you could raise or lower the amoust of boost produced. I know its not gnna change it 4-5 psi but I would guess 1-2 if anyone knows the locatioon or if it even exists that would be great
  2. #2 Re: manual boost increase
    What it actually does it help you get into boost faster or slower. Based on valve rod travel. If you look at the front side of the SC. There's two 10mm screws. Those are the ones you want.
  3. #3 Re: manual boost increase
    GT Level Member 1996pontiac's Avatar
    Livonia, Michigan, United States
    I tried to find this, but i couldnt. I think im going to do headers and exhaust. A pic might help of the location of the screws.
    1999 Red Pontiac Grand Prix GTP/120xxx miles
    Mods- Intake
  4. #4 Re: manual boost increase
    Add flow mods, then do smaller pulley to increase boost and power.
  5. #5 Re: manual boost increase
    Cam, Wouldn't the flow mods negate smaller pulley. Sure it would give you more power, you could retain the same boost levels though.
  6. #6 Re: manual boost increase
    No, because witchcraft.
  7. #7 Re: manual boost increase
    Mar 2013
    amherst
    oh, so which way CCW OR CW?
  8. #8 Re: manual boost increase
    May 2008
    Schuyler, NE
    You loosen them (ccw), push the BBV down all way, then tighten them back up (CW).
  1. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  2. Sudden MPG increase
    By GTLGDP in forum General Tech Discussion
    Last Post: 12-01-2011, 12:58 AM
  3. Mileage Increase
    By TheAce144 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2011, 02:11 PM
  4. Should I increase my timing
    By Xhondaguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2009, 03:18 PM
