your not making any points.. just repeating yourself...
Headers RULE because Aliens wear purple helmets and Potatox2.
When I installed my headers and did no other mods my 0-100 dropped 4 seconds.
Really.. Ok.. You show me where MIT did the study of how headers on a 3800 bolt on car DONT flow any better then tuff guy.. Cause until you can prove it, logic says that they do help with flow. I have seen enough evidence that it does.
I remember my first 3800...
Newbie? I guess I haven't been doing this stuff for 10 years but I have for 2. Learned some stuff along the way. I'm no professional by any means but I've learned a lot with trial and error.
I am not even pissed... And you can call me a newb all you want. Wont hurt my feelings...Or tell you what.. Show me the flow chart of knowledge vs. Newb and show me where I am. THen I can tell you there are lots of factors that go into each part...
There is no flow chart. I don't know what a flow chart would tell you anyways. Maybe once you figure out the more flow does not always equal more power, you will understand better.
Then why do people port heads?
Why do people run cams with more lift?
I will agree that exhaust scavenging is important. so if the primaries on the headers were 15" you might have a point...
You are really trying hard here to compare apples to oranges.
Flow is Flow. Again I understand to a point what you are saying... Just that headers would help if you planed on doing nothing else to your car.
You clearly don't understand at all, or we wouldn't be having this discussion.
I do understand but you are wrong...
Add headers to a stock car and see how much more timing you can get. Why? Because better flow and less heat.
