Thread: Cam stumbles off idle. Is this normal?
Results 1 to 6 of 6
  1. #1 Cam stumbles off idle. Is this normal?
    Mar 2013
    Colorado - USA
    I just pulled the trigger on my S1X cammed L32. I noticed that I have a consistent stumble off-idle when launching. It only lasts a second then smooths right out.
    I scanned my PCM and saw 500+ history misfires on cylinder #6. I have tried new plugs and wires with no effect.
    Is this normal with a cam or am I missing something?
    E85 L32 S1X Heads 105#Crow Springs LQ4 2k+NStarTB Deka 60# Gen1 SLP Headers Stock Plugs
    19 deg GFS and ZERO KR@14 PSI <10% LTFT
    GMPP Struts/Springs SLP Sway Bars Z06 Brakes
  2. #2 Re: Cam stumbles off idle. Is this normal?
    Feb 2009
    flintnasty MI
    Not normal.
  3. #3 Re: Cam stumbles off idle. Is this normal?
    Not normal at all. I could understand random multiples if you didn't disable code P0300.
  4. #4 Re: Cam stumbles off idle. Is this normal?
    Feb 2008
    Did you happen to forget to plug in an injector? Believe it or not, these motors will idle and run halfway decent on 4-5 cylinders until you get on it (forgot to plug two in one time after a blower swap...)
    Sent from my SkyRocket
  5. #5 Re: Cam stumbles off idle. Is this normal?
    Mar 2013
    Colorado - USA
    I'm super sure that I connected all the injectors. I'd expect a code to set before too long with anything disconnected. To be absolutely sure, I'll disconnect each one, one at a time and listen for a change in idle. It could very well be that I have a broken wire or a bad connection somewhere.
    I never did get a proper CPS variation learn. I attempted it several times and I did complete the process, but each time my PowerTuner reported that the test had failed. I'm going to do a full flash in the morning and try the case learn again.
    I just wonder if I should raise my idle at all to accommodate the cam? It's set at 715 RPM while in gear and does idle smoothly. It just chokes for a second when I step on it.
  6. #6 Re: Cam stumbles off idle. Is this normal?
    Mar 2013
    Colorado - USA
    Absolutely right! This was NOT normal. And it took some troubleshooting but I figured out that it was the fault of my old stock injectors. I saw that I had hundreds of misfires in cylinder #6 and the ceramic on the spark plug was bright white after hundreds of miles of normal driving. I pulled the fuel rail and all three of the rear cylinders had cracked disks. #6 was cracked so badly that the disk was no longer continuous and was allowing air to seep past the o-ring.
    A new set of Siemens 60 pounders from ZZP fixed the problem immediately. They were super easy to tune in also. I just reduced the stock IFR table to 60% of original and had single digit fuel trims right away. The idle is smooth as stock even with an S1X cam.
    My old stock injectors were topping 18 msec at 6500 rpm with 11.3:1 fueling. Same conditions now require pulses smaller than 10 msec. Mileage seems about exactly the same too.
  1. Normal idle range for Grand Prix GTP
    By GTP2188 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2011, 01:12 PM
  2. car stumbles at 3200 rpm please help
    By chamberlain198437 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-18-2010, 02:26 PM
  3. Whats normal timing advance at idle?
    By goldgp in forum PCM Tuning
    Last Post: 03-29-2010, 10:18 PM
  4. Surging idle under normal acceleration
    By billy8380 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2010, 10:36 AM
  5. Car stumbles after startup and has a jumpy idle
    By Lionel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-16-2009, 07:23 PM
