Thread: Fuel line pressure
Results 1 to 3 of 3
  1. #1 Fuel line pressure
    Jan 2012
    Pennsylvania
    I have a 04 comp with a xpz cam and all the supporting mods. This is a returnless fuel system. I am running at 60lbs pressure at idle to moderate excelleration. My question is under wot how low can my fuel rail pressure drop to wth 60lb injectors befor I run into a problem and have to maybe add another fuel pump or booster?
  2. #2 Re: Fuel line pressure
    That is a tough question. In theory you want pressure to stay equal at the rpm and not drop off.
  3. #3 Re: Fuel line pressure
    Jan 2012
    Pennsylvania
    I have a wideband 02 in my car plus my aeroforce. so i can scan just about anything I should need to look at. The car does not spudder or miss when the line pressure drops to somewhere around 55lbs. From what I read these 04s with the returnless systems have the voltage regulator for the fuel pump on the fuel pump. So they are really tough to upgrade unless one has the same size and same body style of fuel pump so it can just attach just like the stock pump. My son has a 01 stang that he turboed it also has a returnless fuel system as well. he just added a boost a pump and hasn't had any issues with dropping pressure. I'm wondering if any of the 04 fellows have tried any fuel pump upgrades? maybe I will try another post and see what happens.
  1. Help with Line pressure setting
    By OrangeL67 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-28-2011, 06:57 PM
  2. fuel line nut rusted to fuel line!!
    By Pepino in forum General Tech Discussion
    Last Post: 08-12-2010, 08:25 AM
  3. Fuel line to fuel filter cracked need help asap
    By Jays98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 04:20 PM
  4. A/C low pressure line location on 98 GTP
    By Juanmiguel in forum General Tech Discussion
    Last Post: 02-26-2010, 10:02 PM
  5. Pressure Supply Fuel Line
    By GreenNirvana101 in forum General Tech Discussion
    Last Post: 03-26-2008, 10:08 PM
