Ok so the next phase after i topswap this summer is to install a cam, timing chain and tensioner. the mods i will have are:
-4t65e w/ 3.29's and 245/45-17 that help to give more grip and a slight gearing bump to an est 3.52 if compared to stock tire.
-Speed Daddy Headers
-Full 2.5" exhaust with single magnaflow muffler and resonator
-Ported Heads with Si Valves, viaton seals, L76 springs and retainers
-Ported Lower intake matched to Heads
-Ported GenIII M90 Inlet matched to TB, outlet opened up testing new shape... 3.8" pulley
Even NA, the car has plenty of power down low. So I want a cam that is going to make more mid to top end power. Cams I am looking at are the GT1/2 The XP i think is a little too much as i do not want to run a double roller chain. I will be putting on a new chain and tensioner at the same time. So what cams make more top end power?
