Thread: Spun rod bearing in my engine, Series III is cheaper than Series II, should I?
Page 3 of 3 FirstFirst 123
Results 41 to 56 of 56
  1. #41 Re: Spun rod bearing in my engine, Series III is cheaper than Series II, should I?
    its probably a 04 engine, they mix matched for a few years, they still got plastic lims for a while.
  2. #42 Re: Spun rod bearing in my engine, Series III is cheaper than Series II, should I?
    Feb 2013
    Missouri
    Still cleaning, I have one side done:
    Casting:
    Plastic gasket:
  3. #43 Re: Spun rod bearing in my engine, Series III is cheaper than Series II, should I?
    what are you using to clean the inside of the engine? it looks like new. looks like 1/2 the gold stains are gone on one side. top of the heads look like new too.
  4. #44 Re: Spun rod bearing in my engine, Series III is cheaper than Series II, should I?
    Feb 2013
    Missouri
    Purple Power, soak it in a 1:5 mix for about half an hour and wipe it off. They really weren't that dirty to begin with so they're easy to clean. The valve cover that came with the motor is cracked by the oil filler neck so I have to clean up my old one and it's DIRTY. I also bought a polishing type kit for my dremel to clean up the timing cover oil passages, bur I'm gonna clean it fully first...it's about done. Here's the timing chain
    I haven't pulled anything off of it yet.
    Is there a way to check the timing chain for stretching?
  5. #45 Re: Spun rod bearing in my engine, Series III is cheaper than Series II, should I?
    Feb 2013
    Missouri
    I also noticed that there is 120483 written on the flywheel, so I think they might have been wrong on the mileage. Either way, it looks like it was well cared for.
  6. #46 Re: Spun rod bearing in my engine, Series III is cheaper than Series II, should I?
    Feb 2013
    Missouri
    I have the forged rods, I found a picture of some other rods that have the same casting as mine and they are l32. Mine are cast with 4509.
  7. #47 Re: Spun rod bearing in my engine, Series III is cheaper than Series II, should I?
    Feb 2013
    Missouri
    Oil pan is cleaned and back on, screen is clean as well. There's a bit of cross hatching left, doesn't look like 120483 miles. Timing cover is back on, and so is the water pump, thats about it for today. I went through the oil filter mount and clean up quite a bit of casting flash to help oil flow, lol.
    Pics:
    Connecting rod casting:
    Date stamp under oil pan, not sure if it's Dec '03 or Dec 03, 2007, etc. I'm inclined to believe Dec '03.
    Cross hatching:
    Done for the night:
  8. #48 Re: Spun rod bearing in my engine, Series III is cheaper than Series II, should I?
    I live here. TLSheff's Avatar
    The motor cleaned up nicely. I wouldn't worry too much about the block, the differences between the L67 and L32 blocks are negligible. The big things are the better flowing heads, better supercharger, and stronger lower parts. As long as yours has those it should be a very solid motor.
  9. #49 Re: Spun rod bearing in my engine, Series III is cheaper than Series II, should I?
    Feb 2013
    Missouri
    I forgot to get a picture of it, but I did clean up the casting flash on the oil filter mount. There were 2 spots that were really bad, they had to of reduced the flow by 50%, I swear. Right now I have the mount attached to the timing cover, but it'll be coming back off right before the engine goes in. I put it on to see what it looked like, and not loose the bolts\gasket\mount itself. Bolts aren't torqued, so it'll come right out. My little workshop isn't all that big, and there's damn near 2 engine in pieces laying around here.
    All that's left for now:
    Clean intake side of heads
    Wipe\blow everything off one last time then pour oil all over everything inside the engine, a cap full in each cylinder, then drain the oil pan.
    Finish intake - wait for JB weld to set up a few more days, then finish up cleaning it, sand JB weld, plug coolant holes, and grind the coolant passage at the end.
    Install Intake
    Paint\install valve covers - old front cover is still soaking, gaskets are ordered
    Finish cleaning and possibly paint supercharger
    Finish cleaning engine bay - about 70% done as it sits, I also need a new motor mount.
    ---Drop the engine back in it's home---
    Install supercharger
    Drill\tap throttle body
    Various other small things
    I hoping to have it in during the next week or 2, I'm also doing the DIY shift kit to my transmission while flushing it at the same time. After this whole project, I still have to do the 12 inch brake upgrade, struts, the list goes on.
  10. #50 Re: Spun rod bearing in my engine, Series III is cheaper than Series II, should I?
    I'm a little lost here.
    Since when did SIII heads flow better?
    They have the same crappy castings. Slightly larger valves, but they don't do much.
    Also since when was the SIII timing cover worse?
    It has much larger openings with smoother transitions.
    If you're referring to the bumps in the walls, they really don't make that much of a difference.
  11. #51 Re: Spun rod bearing in my engine, Series III is cheaper than Series II, should I?
    Feb 2013
    Missouri
    The SIII covers do flow worse because they changed the type of casting when Series III's came out, due to the maintance costs to keep the old casting\machines going. The oil passages are much rougher and do no flow as well. Read this: 3800 OILING -TECH- analyzing deficiencies - Page 6 - 3800Pro.com Forum
    As far as the head's, I agree. The intake valve is a whooping .03" bigger, I'm sure it adds at least 350 CFM to the flow (just kidding).
  12. #52 Re: Spun rod bearing in my engine, Series III is cheaper than Series II, should I?
    Here's a post with pictures from the same thread claiming the opposite of what you're saying:
    3800Pro.com Forum - View Single Post - 3800 OILING -TECH- analyzing deficiencies
    Who's right? No one knows.
  13. #53 Re: Spun rod bearing in my engine, Series III is cheaper than Series II, should I?
    Feb 2013
    Missouri
    Whoops, I had it bass akwards, because I was referring to that same post...just that these work computers give slow a new definition so I didn't have time to look it up. I swear that i read a post in that thread talking about how the series III were a different casting that was cheaper to maintain or something of the sort. When I get home tonight and have a descently fast computer I'll look through it again. My bad.
  14. #54 Re: Spun rod bearing in my engine, Series III is cheaper than Series II, should I?
    I am its the internet.
  15. #55 Re: Spun rod bearing in my engine, Series III is cheaper than Series II, should I?
    Feb 2013
    Missouri
    Just to clarify, I'm not arguing. Before I had both timing covers in hand for comparison, these places are where I got my information from...
    L67 vs. L32 short block durability - 3800Pro.com Forum
    Either way, I have a S III cover and that's what I'll be using, lol. It appears the best cover to have is a SII with that passage bored out, and modifying it to be able to use a SI oil pump.
  16. #56 Re: Spun rod bearing in my engine, Series III is cheaper than Series II, should I?
    Feb 2013
    Missouri
    Progress for this build will be in my build thread here:
    http://www.grandprixforums.net/2000-...ics-76934.html
  1. Will a series 1 3800 tranny fit a series 2
    By 2002grandprixgt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-20-2012, 01:06 AM
  2. What series engine is this?
    By copgtp in forum General Grand Prix Discussion
    Last Post: 02-27-2012, 08:52 PM
  3. series 1 snout on a series 2 supercharger
    By junkyarddsm in forum General Tech Discussion
    Last Post: 05-12-2011, 06:19 AM
  4. 2004 series 3 3800 swap to 1998 series 2 car?
    By carpenterbronco in forum General Tech Discussion
    Last Post: 04-13-2010, 11:12 PM
