Thread: need help o2 sensor
Results 1 to 7 of 7
  1. #1 need help o2 sensor
    GT Level Member titanfan12's Avatar
    Jan 2013
    west palm
    will the o2 sensor cause my 99 gtp sc to stall? (note i have bad mpg right now as well)
    because im running out of options right now
  2. #2 Re: need help o2 sensor
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    stalling usually is mass air flow or even a weak fuel pump. o2 would be hard to believe it could cause a stalling issue. could always try to unplug the o2 see how it runs. have u had the engine light scanned for codes? i know the mass air flow and the o2 get their power from the same fuse, maybe the fuse is blown its under the hood on pass side of engine compartment.
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  3. #3 Re: need help o2 sensor
    If your O2 isn't heating up, it will cause the car to run horribly when the switch happens from ICM to PCM. You can also see this if you are watching the O2, based on the mV staying super low.
  4. #4 Re: need help o2 sensor
    Jan 2013
    west palm
    well i have replaced the maf sensor and yes ive scanned it many times with no codes being thrown
    ive also replaced many things and my car just stalls whenever but its usaully in the first 5-15 minutes of running
  5. #5 Re: need help o2 sensor
    GT Level Member GP Guy 07's Avatar
    Feb 2013
    Elgin
    For a 02 sensor a live scan is needed to see in real time data.To see if it's lazy or not,but if the 02 is junk you'll know the car will run like crap.
    07 GP black on black,SPO spoiler,grills,hai,aftermarket rims,Led tails,drilled+slotted rotors
  6. #6 Re: need help o2 sensor
    Jan 2013
    west palm
    i actually have another code reader that does real time and what would or should i say what should it look like
  7. #7 Re: need help o2 sensor
    Feb 2013
    Elgin
    Like long peaks^^^ a steady stream of them.If you need to see them,look on youtube.Thats how I found out mine were shot.Hope that helps.
  1. O2 Sensor not working... P0171 new sensor still no data from O2?
    By Z34Phoenix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2012, 12:20 PM
  2. question about low coolant sensor,fuel level sensor,and the
    By spider4 in forum General Tech Discussion
    Last Post: 11-26-2011, 09:19 AM
  3. camshaft sensor or crank sensor?
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-06-2010, 04:43 PM
  4. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
