Well ll be pulling my L67 on my gre gtp to put into my Na 40th sometime this year depending when i finish it all. I will be putting a L67 i picked up at the junk back into my gtp and selling itchanged all gaskets but won know if itturns over fine or has any issues till i crank it over. I have some questis when you have a spun bearing or a rod knock do you end up with some metal shavings on the oil pan or no?
Also for anyone that lives in strict emision places like me in cali. What cam would you run that can pass smog without issue i am undecided between VS or XP?
I use the car as a DD and street use and some track use but more of a street car. 91oct
some pics of the engine i will be pulllig out of my gtp and the one going in it.
The Engine Going into the GTP
