Thread: 1998 3.8L V6 Supercharged GTP Won't start- Fuel??
Results 1 to 3 of 3
  1. #1 1998 3.8L V6 Supercharged GTP Won't start- Fuel??
    Apr 2011
    Edmonton
    Hi everyone,
    So today I drove my 1998 Grand Prix GTP all day, with considerably low fuel and had no problems. Turned it off and had it sitting in my driveway (it's below freezing outside) and after about 30 minutes the car would not start up again. Starter and other engine components seem to be fine. Had gas delivered (about 6 litres) and still would not start. Stutters but won't start up. Really need to get it going as it is my only means of transportation at the moment. Any suggestions would be greatly appreciated.
    Thanks
  2. #2 Re: 1998 3.8L V6 Supercharged GTP Won't start- Fuel??
    Try spraying starting fluid in it and see if it starts or try unplugging the maf sensor
  3. #3 Re: 1998 3.8L V6 Supercharged GTP Won't start- Fuel??
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    sounds like the fuel pump is worn or weak from running it low on fuel. if it doesnt start after it sits with gas then it probably needs a new fuel pump. there is an access for the pump in the trunk right behind the back seat where the pass thru is for the trunk under the carpet...pretty easy to change the pump
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  1. My 1998 Pontiac Grand Prix Gtp Supercharged
    By Xereck in forum Members Rides
    Last Post: 02-12-2012, 08:19 PM
  2. 1998 Grand Prix GTP 2 door 3800 Supercharged
    By Litt52 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-29-2011, 07:24 AM
  3. 1998 Pontiac Grand Prix GTP Supercharged
    By Spartan GL in forum Introductions/Noob Questions
    Last Post: 12-07-2009, 11:17 PM
