Thread: plugs?
Results 1 to 20 of 23
  1. #1 plugs?
    Aug 2008
    Long Island, New York
    im changin my plugs soon, and ive already established that i want 104's... but now i am torn between the regular auotlite 104's, and the autolite XP 104's?
    which do you think is better?
  2. #2 Re: plugs?
    GT Level Member riceburner's Avatar
    Aug 2008
    denver, co
    whats the diff?
  3. #3 Re: plugs?
    Aug 2008
    well they are iridium plugs. they r more expensive... are they any better?
    https://www.zzperformance.com/grand_...=806&catid=109
  4. #4 Re: plugs?
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    its already established that straight copper plugs are what our engines like best, but they dont last long. so the iridium is supposed to find a "middle" and still get most of the advantages of copper yet more longetivity.
    someone correct me if im wrong.
    2004 GTP CompG. SPO Package.
    3.6MPS, 3" DP, Powerlog, 180Tstat, Wizair, Autolite 104's, 20* timing, PRJ Wires. PRJ Tune.
  5. #5 Re: plugs?
    Aug 2008
    and also, what is a good gap to run these on? and anyone know the torque rating for the plugs?
  6. #6 Re: plugs?
    TDCRacing
    Guest
    Get copper plugs. Get 605's. Run a gap of 45. Just tighten the plugs down. If you would actually torqu the plugs you would probably need a torque wrench that has inch pounds instead of FT. pounds.
  7. #7 Re: plugs?
    TDCRacing
    Guest
    You wan't the hottest spark you can get without causing any KR.
  8. #8 Re: plugs?
    Aug 2008
    ok, how long will these last for approximately? so i know when i need to change them
  9. #9 Re: plugs?
    TDCRacing
    Guest
    Change them out at about every 8000 miles.
  10. #10 Re: plugs?
    Feb 2008
    South Bend, IN
    .045 gap? I thought .055 was the recommended.
  11. #11 Re: plugs?
    TDCRacing
    Guest
    I've never ran a .55 gap...not even now. To be honest i'm not sure what is oem specs but i don't belive it is .55. I could be wrong though... One time I was....just once though....lol
  12. #12 Re: plugs?
    Barksdale AFB, LA
    Quote Originally Posted by TDCRacing View Post
    OEM is .060 I believe. 0.55 would be half an inch.
    2009 Subaru Impreza WRX STI
  13. #13 Re: plugs?
    Donating Users
    W-S, NC
    ^ yep oem is .060...thats what i gapped mine at. Forgot about the previous threads when I installed them lol.
  14. #14 Re: plugs?
    Aug 2008
    i plan on going down to a 3.4" or 3.5" pulley after a couple more mods... should i still go for the 605's or the 104's?
  15. #15 Re: plugs?
    TDCRacing
    Guest
    wELL IF YOUR NOT GOING TO GO TO A 3.4 OR 3.5 WITHIN 8000 MILES THEN JUST GO WITH THE 605'S TILL THEN. But yeah once drop to oneof those thats the plug you'll need.
  16. #16 Re: plugs?
    Aug 2008
    yea... i plan on going down to a 3.4 hopefully within 8000 miles... all i really need is the powerlog, the 180 tstat n the plugs n i think i should be good enought for at least the 3.5", maybe even the 3.4 then im gonna scan her up
  17. #17 Re: plugs?
    TDCRacing
    Guest
    Thanks for the correction!
  18. #18 Re: plugs?
    Hoffman/Schaumburg, IL
    I say run NGK's iridiums, with the iridiums I picked up 2 mpgs
  19. #19 Re: plugs?
    Aug 2008
    KCMO
    i have a stock 06 S/C except for full synthetic and a drop in k&n what plugs should i run?
  20. #20 Re: plugs?
    Feb 2008
    South Bend, IN
    what the h*ll. I thought .055 gap was the cats meow for mild mods?
  1. TRI-55X Plugs=bad KR for my car?
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-25-2008, 04:44 PM
  2. Brisk LGS plugs my take on them.
    By GeddyLee in forum General Tech Discussion
    Last Post: 05-09-2008, 08:34 PM
  3. Plugs???
    By crashman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2008, 10:00 PM
