Thread: replaced power steering pump now trouble idling
Results 1 to 15 of 15
  1. #1 replaced power steering pump now trouble idling
    Jan 2012
    Abilene, KS
    so today i replaced my power steering pump and got everything back together first time with no problemsand didnt end up with any magical parts that didnt have a home. but i started it up to put more anti freeze in and let it idle for ten minutes or so and it ran fine so i put the tire on and let it off the jack and got it and started to drive. i was a block or so from my house and turned the corner and no problems. as i come to a stop sign my rpms went down to 500 or so and then back up to 1500 and fluttered for 10 or 15 seconds. i proceeded down the road and come to the next stop sign and it just died.so i started it up and it was fluttering again but didnt stop. so i brought it back home and it ran fine at the only stop sign on my way home. i pulled in the garage and it died and now the way it will stay running is if the throttle is held down. any ideas?
  2. #2 Re: replaced power steering pump now trouble idling
    Unplug the MAF sensor and see if will run on its own.
  3. #3 Re: replaced power steering pump now trouble idling
    Jan 2012
    Abilene, KS
    still had to give it gas o start it then it fluttered between 1000 and 1500 rpm. shut it off and turned started it again and it would stay runnin without me givin it gas
  4. #4 Re: replaced power steering pump now trouble idling
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    Vacuum leak? Maybe you bumped a hose
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  5. #5 Re: replaced power steering pump now trouble idling
    Jan 2012
    Abilene, KS
    p0101 and p0102 googled em and cant make sense of them they are talkin maf sensor but i didnt mess with that. i unhooked the battery but thats all i could think of but that shouldn't mess with it. there was a vacuum line on top that i moved but it wasnt cracked or anything
  6. #6 Re: replaced power steering pump now trouble idling
    Jan 2012
    Abilene, KS
    scratch that found a little crack...now i need help identifyin the part i got a 99 gtp the part is right it the middle of the backside of the supercharger. it mounts to the alt support bar it has a hose on the front side of the engine that goes about 2 inches and then curls back around towards the back
  7. #7 Re: replaced power steering pump now trouble idling
    Jan 2012
    Abilene, KS
    comes out of the front of the map sensor i think
  8. #8 Re: replaced power steering pump now trouble idling
    sounds like the evap. its on the right rear of a sc'ed motor, and the map is to the left, standing at the bumper looking over the blower.
  9. #9 Re: replaced power steering pump now trouble idling
    oh i forgot to ask, you found the wire clipped to the p/s pump? and un hooked it before ripping it off the rear knock sensor? no code for that, just thought id ask.
  10. #10 Re: replaced power steering pump now trouble idling
    Jan 2012
    Abilene, KS
    there were no wires on it just a rubber line and a metal line and it was the evap canister purge sol vlv line. i changed it and still the same stuff
  11. #11 Re: replaced power steering pump now trouble idling
    Jan 2012
    Abilene, KS
    any other ideas?
  12. #12 Re: replaced power steering pump now trouble idling
    you doubled checked all the vac line routing to the diagram posted?
    the T's like to break and leak, under the sc snout
  13. #13 Re: replaced power steering pump now trouble idling
    Jan 2012
    Abilene, KS
    thanks i already found it but thats where it was and none of the auto part stores in town had the right sized t's so i jus jerry rigged it like everything else on the car
  14. #14 Re: replaced power steering pump now trouble idling
    i got these cute little T's from advance auto, 2 came in the pack, they are perfect at 3 bucks.
  15. #15 Re: replaced power steering pump now trouble idling
    Jan 2012
    Abilene, KS
    i used them but i could only get em in a variety pack of 18 million an they didnt have any line small enough so i had to buy a pack of 4 little 2 in pieces that was 5 bucks
  1. Power Steering Pump Going Bye Bye?
    By burgundybullet in forum General Tech Discussion
    Last Post: 02-28-2013, 11:15 AM
  2. Replaced Power Steering pump, now making noise.
    By fri3dchick3n in forum General Tech Discussion
    Last Post: 05-14-2011, 03:06 PM
  3. Need New Power Steering Pump?
    By brandonl2000 in forum General Tech Discussion
    Last Post: 12-05-2010, 01:59 PM
  4. replaced power steering pump and now it is squeeling and leaking badly! Help
    By Cheri in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-07-2009, 08:10 AM
  5. Power Steering pump
    By airhead in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2008, 07:16 AM
