Thread: 98 Gtp No Spark
Results 1 to 3 of 3
  1. #1 98 Gtp No Spark
    Nov 2011
    Laredo, TX
    I got a 98 grand prix gtp and it died out on me and it doesnt start anymore has no spark and dont know wat is wrong with its can anyone helo me out here?
  2. #2 Re: 98 Gtp No Spark
    Florida
    No spark at all? Did you pull all the plugs and wires and check each cyl. for spark?
    does the car spin over at all?
    If you have no spark at all, it's probably a bad ICM (Ignition Control Module). It's the plate that the coil packs sit on top of. Also check to make sure that the wiring harness plug that goes into the ICM (just infront of and under the coils packs) is plugged in, and no wires are broken. Same with the Connector between the ICM harness and the main harness. (Big bulky connector infront of the fuel rail, just to the right of the coil packs)
  3. #3 Re: 98 Gtp No Spark
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    ses?
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  1. Need Help With No Spark!
    By wa04compg in forum General Tech Discussion
    Last Post: 04-01-2012, 03:52 PM
  2. 08 with no spark
    By JJB in forum General Tech Discussion
    Last Post: 03-28-2012, 10:27 PM
  3. 3.1 and no spark
    By TAYLORPCC in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-25-2010, 01:45 AM
  4. No spark HELP!!!
    By Machzzzz1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2010, 12:30 PM
  5. no spark
    By faboskay57 in forum General Tech Discussion
    Last Post: 07-10-2008, 07:41 AM
