Thread: vibration while accelerating
Results 1 to 7 of 7
  1. #1 vibration while accelerating
    california
    where the drivers side axle slips in to the trans it has slop. i can grab the axle and move it up and down. is the trans dust or is a bearing worn? has this happen to ant one else?
  2. #2 Re: vibration while accelerating
    If its shaking on acceleration only and goes away once let off, then you have a bad axle.
    The insides of the axle could be broken and causing the play.
  3. #3 Re: vibration while accelerating
    california
    this is with the brand new axle only the drivers side the old one did the same so i changed it and it has not changed but the passenger side is tight
  4. #4 Re: vibration while accelerating
    tennessee
    the axle splines should move very little when inserted into the trans... are you lowered because lowering causes axle geometry changes and vibrations under acceleration
  5. #5 Re: vibration while accelerating
    california
    the car is not lowered its all stock, with the axle out i can mose the shaft thats inside the trans.
  6. #6 Re: vibration while accelerating
    tennessee
    i dont want to scare you but id take it to a shop for a more in depth analysis... especially if it does it with a new axle, because i dont remember ever having any movement in the trans last time i changed mine
  7. #7 Re: vibration while accelerating
    tennessee
    1998 gtp 4t65e-hd case cover assembly... pardon my terrible drawing 431 is the part that might do it just a suggestion not 100% and should be able to do it with the trans still in the car if ur able to get the driver side trans cover off... guess i should mention tht this is an image of the trans flipped on its back
  1. bad vibration while accelerating help please!!!
    By 01RedfireGT in forum Brakes/Suspension/Chassis
    Last Post: 09-29-2012, 08:54 PM
  2. My GTP Shakes When Accelerating.. Please Help
    By Supercharged03GTP in forum Brakes/Suspension/Chassis
    Last Post: 05-10-2012, 08:20 AM
  3. Vibration while accelerating
    By erichanson2009 in forum General Tech Discussion
    Last Post: 03-01-2012, 12:08 AM
  4. Stuttering when accelerating
    By bigwillie in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-11-2011, 08:59 PM
  5. GTP stalling while accelerating
    By SUGAR in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2010, 07:06 PM
