Thread: Supercharger leak
Results 1 to 14 of 14
  1. #1 Supercharger leak
    Hamilton OH
    I had a idler pulley for the supercharger break and the belt shredded and wrapped all around the supercharger pulley. I thought it messed up the snout seal. So I replaced the idler pulley and the snout seal and put fresh oil in it. Took it for a drive and when I got back it had threw oil all over again. My question is could I have messed the seal up when I installed it or did teh belt that got wrapped around the supercharger pulley maybe bent the shaft a little and that is tearing up the seal. Also if I decide I need to replace the snout wheres the best place to get it. Thanks for you time and input.
  2. #2 Re: Supercharger leak
    How did you go about changing the seal?
  3. #3 Re: Supercharger leak
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    the aftermarket seals always leak also did u use the socket trick to put the seal on and lubed it up well before you installed it...prob wouldnt have messed with it was prob still ok..you also may have rolled the new seal if u didnt use the socket trick to install
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  4. #4 Re: Supercharger leak
    Hamilton OH
    Quote Originally Posted by 00grandprixgtp View Post
    I used a socket but maybe didn't do it right. Is there a link on how to install it and make sure it's right. What should I do and buy a new seal
  5. #5 Re: Supercharger leak
    Hamilton OH
    It tore up the old seal when the belt got tangled in behind the supercharger pulley. That's why I replaced it.
  6. #6 Re: Supercharger leak
    Nov 2012
    Madison
  7. #7 Re: Supercharger leak
    Hamilton OH
    Is there a snap ring that holds the seal in
  8. #8 Re: Supercharger leak
    Yeah
  9. #9 Re: Supercharger leak
    Hamilton OH
    That's y it's leaking its missing that snap ring. Thanks guys.
  10. #10 Re: Supercharger leak
    Hamilton OH
    Should I replace the coupler while I'm doing this stuff or if everything feels tight leave it alone.
  11. #11 Re: Supercharger leak
    I'd leave it alone if it's fine.
  12. #12 Re: Supercharger leak
    Hamilton OH
    Where do I get the snap ring
  13. #13 Re: Supercharger leak
    Didn't you pull one off?
  14. #14 Re: Supercharger leak
    Hamilton OH
    No there wasn't one there I think when the belt tangled up it broke it
  1. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  2. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  3. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  4. Supercharger leak and PSI problem
    By BullittGP1998 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2010, 02:01 PM
  5. Coolant leak below supercharger
    By dlemmen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-21-2009, 01:15 PM
