I don't see a way to pull the cam with the engine in the car completely as the inner fender is in the way, you pull the intake, and rockers leave the heads on unless there is a problem that needs addressed, rockers should be fine as long as the rest of the engine is in good condition (if the oil hasn't been changed since it was new don't try and add power basically)
