I just picked up a 98 gtp to do some work on, however without a good scan tool this has got me puzzled. The car runs fine after 2k rpm, when you first step on it it stumbles a little bit and then pulls decent. Im pulling a p0102 code with my pocket scanner, all the wiring to the MAF looks good, and i was told the MAF was replaced a couple years back. Another thing im noticing is that under WOT the DIC is only showing half boost, at redline it sounds like the belt is slipping to me but its making a loud squealing noise at redline. Any input would be great guys, thanks for your help
