Thread: "SI Valves" Valve springs? (PN: VS 1118)
Results 1 to 11 of 11
  1. #1 "SI Valves" Valve springs? (PN: VS 1118)
    Jan 2013
    Australia
    hey people,
    In my never-ending quest to find a perfect valve spring to be used with VS cam or 1.95 YT roller rockers Ive come across these:
    SI VALVES
    According to this graph they actually have a lower spring rate than stock L67 springs but still have a higher seat pressure needed for the increased lift. Looks like the SI VS 1118 the perfect spring for our L67 cam applications
    Anyone got any experiences with this brand "SI Valves"?
    Cheers
  2. #2 Re: "SI Valves" Valve springs? (PN: VS 1118)
    May 2008
    Schuyler, NE
    IMO, I wouldn't put SI Valve anything on my lawnmower.
  3. #3 Re: "SI Valves" Valve springs? (PN: VS 1118)
    Jan 2013
    Australia
    lol ok then... I take it the don't have a good reputation...
    What about PBM 110#?
  4. #4 Re: "SI Valves" Valve springs? (PN: VS 1118)
    May 2008
    Schuyler, NE
    PBM's are great springs. Those would be a good choice.
  5. #5 Re: "SI Valves" Valve springs? (PN: VS 1118)
    Jan 2013
    Australia
    yeah according to that graph PBM 110's also have a milder spring rate than even stock L67 springs.... so how come everyone always recommends L76 springs? L76 springs have a fairly higher spring rate than the PBM 110's.
    So out of all those shown in the graph the PBM's are the mildest on the timing chain and tensioner? Would that be a accurate statement?
  6. #6 Re: "SI Valves" Valve springs? (PN: VS 1118)
    May 2008
    Schuyler, NE
    If that chart is correct, then yes.
    I don't know why people recommend L76 springs...they aren't even rated at enough lift for a VS cam.
  7. #7 Re: "SI Valves" Valve springs? (PN: VS 1118)
    Jan 2013
    Australia
    Really?
    I thought VS cam lift is .507" and .512" and L76 springs are rated to .520" lift?
  8. #8 Re: "SI Valves" Valve springs? (PN: VS 1118)
    May 2008
    Schuyler, NE
    With 1.6 rockers it is, but if you're using stock rockers, you'll have higher lift than that.
  9. #9 Re: "SI Valves" Valve springs? (PN: VS 1118)
    Jan 2013
    Australia
    Ah yes, you guys have some cars with 1.66 rockers and some with 1.6 rockers over there right?
    I'm pretty sure we don't have that situation here in Aus.
  10. #10 Re: "SI Valves" Valve springs? (PN: VS 1118)
    May 2008
    Schuyler, NE
    Stock rockers are not technically a fixed ratio. With the stock cam, they are rated 1.6 to 1.66, depending on who you ask. However, due to their design, the rocker ratio increases as cam lift increases. So with a VS, your ratio may be closer to 1.7.
  11. #11 Re: "SI Valves" Valve springs? (PN: VS 1118)
    Jan 2013
    Australia
    yeah I was wrong anyway... stock rockers are rated as 1.65 over here.... interesting point about the dynamic ratio though
  1. "Extra Clips" in 4T65E Transmission Valve Body?
    By agrazela in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-30-2008, 03:17 PM
