hey, anyone know of any mock ups or anything anywhere for a duel 255 or 340 fuel pump setup for the gtp? I've been kinda looking around and not seeing anything so I turned here. hope to here something, thanks
What kinda mods u got to need more than 1 pump...or even 1 Hugh performance pump
To get 2 in-tank pumps to work, you have to cut part of your bucket away, as the venturi won't keep up. And, plan on never letting it go below half a tank.
A platform that will never need dual pumps.![]()
A platform that will never need two pumps? Harsh lol stage 3 heads, l26 intake, st4 turbo cam, s259 72mm turbo, e85 on #80's, a few other goodies we wont mention, and a triple edge trans, was just at zzp two days ago and when I'm done looking for 580+ whp with a good dyno tune.. so yes two fuel pumps sounds right to me.................... but any ways do you know if the f-body setups are in any way close to the setup on ours? because if so I'm sure I can find a mock up from them to base it all off of. thanks guys
Not tryin to argue but Steve at zzp told of a purple one with a really close setup to mine that was maxing out his duel 255 and #80 injectors at 595 whp.... So this is why Im continuously saying duels.... I understand and am totally with ya that a massive 340 sounds like it should more than work but I'm goin by wut zzp is tellin me they've seen on the dyno...Sooo idk
In my opinion, the 340 is a huge pile of junk.
Yup that's the one he was talking bout. And steel tank and sump it like a race car pretty much? Also do you know was it just a faulty pump, bad setup, or? Because I was just thinking dual 255 pumps because I already have one that's working great but if its not big enough then ya..
most commonly from what i have seen is the second fails due to overheating, or an electrical problem.
other times, people use a cobb switch but the switch always seems to fail.
Sry phone posted that twice.....so you would need two rewire kits then and just modify the bucket? Would you still be able to.use the.venting tube if I make it bigger with short Y's to the pump?
